Question about GPS
Trying to start the GPS without the SD card
Hi! I have tried to start the GPS without the SD card. I have taken the SD card out, turned the power on, and it returns to the same menu with Multimedia and Settings without the SD card. It does the same thing with the SD card in. I am beginning to wonder if maybe the problem is with the SD card. I think that maybe I should try to purchase a new SD card. But I really don't want to have to pay any money to fix it, unless it is absolutely necessary and I know for sure that it will fix the problem. What do you think I should do?
  • 13,433 Answers
Try asking someone else, have you tried updateing the firmware on the gps?
Posted on Jul 17, 2008
720 Go is frozen. Press the reset button and nothing still get the same screen with a harddrive in the corner. Put it in the cradle and the computer doesnt see the unit when it is on?? Have tried to let...
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for at least 20 seconds. The reset button is a hole at the base/bottom of the device.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds or more, until the GPS starts up. It may take a minute or two of holding it down.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Sep 02, 2011 | Tomtom GO 700 GPS Receiver
The tomtom X-l doesnot start anymore. It shows the card taken out of the themtom with a red cross over it
If the sd card is in the tomtom then it has become corrupted, have you tried reading the sd card on a pc using a card reader?
Feb 24, 2011 | Tomtom ONE XL GPS
Will not power up when charged
try restting your 920
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds.
    Press the On/off button for at least 5 seconds.
  5. If your device uses an SD card, insert the SD card.
Aug 26, 2009 | Tomtom GO 920 GPS Receiver
How do you save start up files and maps from a SD card to a computer for reinstall if card is corupted?
There are programs designed to try recover flash memory but in my experience they are hit and miss in what they do.
Many gps devices will start up WITHOUT the sd card
If it does that is the time to BACKUP the device.
You may well have lost what was on the SD card but if you have a backup from an earlier point where you had an sd card in the gps you can reformat the card and start again from there by restoring.
Aug 07, 2009 | GPS
I have a tom tom go 710 and need to know how to reset it, and when i turn it on, the screen shows that I need to install SD card. I am wondering if I need the SD card for it to work properly?
To reset your TomTomGo710 device, do the following:
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
tomtom go710 map data is on SD card without it, it will not work.
Apr 21, 2009 | Tomtom GO GPS Receiver
Will not let me listen to music stored on sd card
Hi, how dit you format the SD card. It should be formatted as Fat32 before you store music on it. If the card does not showup in the browser there is an issue with the format. In some instances the card could be incompatible with the zumo. So format it first (Fat32), copy some mp3 files to it (id use 128 kbps mp3's to start off with) plug it in and see what happens. If nothing, try a different brand/size card. I use 4GB SDHC card made bij sandisk without issues.
Jun 13, 2008 | Garmin zumo 550 GPS Receiver
Tomtom go 300
before you start take out sd card. 1 turn tomtom upside down. 2 see reset button? 3 use paper clip to press (press for 15secs) 4 now turn on tomtom (hold power button for approx 5secs. 5 re insert sd card. after a few minutes you should have signal. hope this solves your problem.
Mar 19, 2008 | Tomtom GO 300 GPS Receiver
My gps will not recognise my sd card or turn on
Try the clear flash utility. It worked for me. Martin
May 06, 2007 | Tomtom GO 510 GPS Receiver
SD GPS
I have read some Information about Toshiba PDAs. There is a technique called SD™ IO card. In the technical specifications I found this Info: 1 x SD™ card slot (supports SD™ memory card, SD™ IO card, MultiMedia card) So when SD™ IO card is the same as Bsquare SDIO Now! tecnique...
Sep 08, 2005 | Toshiba e750 Pocket PC
GPS Logo
76 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
