Question about Protron PLTV-32 Television
DEAD, replaced all "pregnant" caps on PS board.
Still no power, Primary PS is ok. nothing out of SMPS. TIA, John
  • Jaime Hernandez May 11, 2010
    Measure the standby voltage with the power supply connected to the AC line.
    You should get 5 and 12 volts even if the TV is not powering up.
  • 2,326 Answers
Any updates?
Posted on Jul 18, 2008
Djx 750 - no power - transformer dead?
Actually, you may be in luck. A burned cap means that it has done exactly what it's supposed to do. So...you might stick an identical one in there -- it's a 0.1 uF cap, and you can find these at Radio Shack (0.1 uF 50V) or online. They are cheap, so give it a shot.
Feb 16, 2014 | Behringer DJx700 5-Channel Pro DJ Mixer...
Will not turn on
Check the power plug for power. If this is OK then you likely have a blown TV power board, and the primary components are affected. The caps in the primary circuit can be replaced if they are blown, but otherwise you may need a new board.
Nov 26, 2013 | Sanyo DP32649 31.5 in. TV
Had a power surge on this tv model klv32s400a, no standby led completly dead. Have opened and checked the power supply as far as I can, supply is present on primary side of transformer but not getting to...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 10, 2017 | Sony KLV32S400A 32 in. LCD TV
My PC doesn't power on i changed PS but nothing happened Plz help
It seems the problem lies in the SMPS. Before replacing yr SMPS, try to chck the power supply socket with a tester. If the power supply is ok, then the problem is with yr SMPS, pls replace it.
Aug 04, 2010 | Dell OptiPlex GX520 PC Desktop
The tv does not turn on. Power on lamp remains dark. Power cable checked out ok
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Feb 18, 2010 | LG 20LS7DC 20 in. LCD TV
Polaroid FLM373b No power.
When the filter capacitors went out , the power supply will feed AC instead of DC into the circuit board and may have damaged other circuits. Do you get the 5vdc standby voltage? it should be on one of the power supply out put connector the minute the you plug in the TV, you must have this before go further.
Dec 13, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Sanyo ST-21G1 dead set
There should be a small valued cap in the primary side (22ufd?) at 250V. Check that. Also, look for other small caps int he range of 2.2ufd with 200V ratings in the same general area.
Dan
May 07, 2008 | Televison & Video
Power but no picture
This unit stumped me.. The reason being is that the power supply normally has 2 parts, a primary control line and then the main power supply. The purpose of the primary control line is to talk to the main control board, make sure there are no errors upon power up and then startup the set with high voltage. The problem is that the primary control portion is not working.. With that being said, it has no way to control the set for startup and initalize the processor for the video/menu. What is supposed to happen is when this is dead, the set should do nothing and the relays should be tripped going into protection fault mode. A very backwords design for failure on this unit. Anyways, replace caps c502, c503 and c521 on the main power supply unit. Replace the existing 50v .47 uf with a 1uf @ 50v to prevent the failure again. The other 2 are 47yu at 35v, I would jump the volts to 50 on that again to make sure it dosent happen. Becareful of the ps removal, the 15+ fets are screwed to the chasis and locked down do to heat, do not remove the protective coating or risk ps failure. Enjoy your tv.
Mar 05, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Protron PLTV-32 Television Logo
53 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
