Question about E-Machines eMachines Monitor E15T4
E machine monitor
My monitor is only 2 yrs old, i continues to start over and over with power safe mode.....how do i keep the screen up and turn power safe mode off......thanks
    Scholar:
  • 172 Answers
Check the settings control panel, power options to make sure the setting is not engage to power saving after "minutes" if it is change to the require time or disable, then apply the settings and exit. if this is not the problem, the other most common problem with these emachines and random and frequent unplanned shutdowns is a the motherboard itself. Contact me for further support on this item
Posted on Sep 15, 2008
I just have a OPTIPLEX SX280 and try to connect to my old montor (VGA), when I turn on power it seem run starting but the it show up on monitor screen "can not display video mode". What is that...
When you first power on the computer tap the <F8> key to bring you to a menu that has the option of running in safe mode. If the computer boots up in safe mode and you are able to see the display on your monitor then your current video drivers are not supported for the old monitor.
Sep 10, 2011 | Dell OptiPlex SX280 PC Desktop
I just got a monitor, samsung LS19GSESS/Xaa from my friend cause he got a new 22" . However when i tried it on my computer it doesn't work. So when i plug the monitor onto my video card, 5770 brand...
what you are seeing is the monior test and adjust features. If your old monitor worked then the computer is not at fault. Try this: Boot up your computer and while doing so continually press the f8 key, ever second or so, don't hold it down, just keep pressing it. eventually (if the monitor works) a screen will pop up (assuming windows operating system). when and if you see this screen choose the option "start windows in SAFE mode" if this works just wait till it boots up. After it boots up and tells you its in safe mode, right click somewhere on the screen and choose either "screen resolution: (if windows 7) or "settings if windows XP. change the screen resoltion to the lower choice 800 X 600 Or somethign close to this. Now reboot again in normal mode. if the monitor now works you can go through the process again to set the resoltuion higher, 1280 by ? or something. let me know if it works.
Mar 11, 2011 | Samsung Televison & Video
Monitor keeps glitching. right side of screen completely black. is there a way to reset the monitor
Hi
Thank you for your query
If your monitor is black on the right hand side, this indicates that the LCD screen may be burned out
Please try the following
1) Switch on Laptop
2) Continuously press the F8 key until a start up menu presents itslef
3) Choose safe mode
4) Oncein safe mode look at the screen, i believe it will be the same
If so you will need to book the laptop in as part of the screen has burnt out
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | Compaq Presario Notebook
Screen goes black. the power light is on, but the picture goes out. if i turn the power off, then on again it comes back for about 5 seconds, then goes black again.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
Sep 08, 2009 | Dell Dimension E510 PC Desktop
LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
May 11, 2009 | LG L1915S 19" LCD Monitor
Safe mode keeps appearing on my desktop
This may sound stupid but your F8 key may be stuck. Has anything been spilled on your keyboard?
Jan 31, 2009 | Computers & Internet
Sleep mode Philips LCD Monitor
I think u need to check monitor properties.In those properties in screen saver mode there is a power button.u need to select that power button and change the turn off monitor option.
Sep 15, 2008 | Computers & Internet
Monitor
I would try going into your video settings, right click on your desktop then go to properties, In the window click on the Screen Saver tab and go to the bottom where it says monitor power click the button that says powermidway towards the bottom there will be 3 settings, the first being "turn off monitor" with a drop down menu... set it to Never. That should keep it from turning off. If there is something wrong with the cables and its stil shutting off, you may just need to gte a new power cord, its usually the same cord used for the computer power and they aren't very expensive, Radio Shack probably carries them. Hope thishelps, Good Luck!
Apr 24, 2008 | E-Machines eMachines T3830 PC Desktop
HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Dec 19, 2007 | Computers & Internet
E-Machines eMachines Monitor E15T4 Logo
101 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
