Question about Whirlpool Refrigerators
Hi there, have bought a whirlpool arc2210 fridge freezer,just discovered on off switch to the inside right of fridge unit,just above the temp control swith.cant find manual and i'm curious! cheers susan craig.
  • 41 Answers
Sounds like the anti sweat switch for keeping the outside of the freezer from sweating on humid days dan
Posted on Jul 16, 2008
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
Hi, I have a whirlpool american fridge freezer. Model number 3XARG4886GFD1, TYPE E27SSA. The unit has been standing idle for about 9 months disconnected. We have connected it up today to both...
you should hear the water solenoid valve click in the lower rear area when you push the pressure paddle for water in the front,if no click,check for voltage at this solenoid and if powered when paddle is depressed in the front,remove and disconnect solenoid valve and check the valve for continuity
Aug 03, 2011 | Whirlpool Refrigerators
5 year old whirlpool fridge/freezer uk style freezer on bottom. freezer still cold but not working? fridge part still working but temp seems reduced. no ice at back of freezer area inside?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 10, 2011 | Whirlpool Refrigerators
The freezer is not cold enough but i don't see a temperature control inside. Does the one in the fridge also control the freezer?
Correct. The fridge works 100% off the freezer anyways. So they installed the sensor right between the freezer and fridge if you look inside you can see it.
Whirlpool refrigerator repair orange county, ca
Feb 06, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
Fridge leaks water on the inside, is not condensation
Hi!!! Your drain line is plugg, also there might be some dirt plugged so remove the evaporator panel are clean the drain line..deb5a30.jpg
Jan 04, 2009 | Whirlpool ET1FTKXK Top Freezer...
Freezer suddenly stopped freezing and fride is not getting cold
Hi, I would try putting your refrigerator and freezer control switches on medium. Good Luck,I hope this helps you out.
Nov 07, 2008 | Whirlpool Refrigerators
S20b rsb21 whirlpool
Your freezer section has a defrost system problem. A device (Timer) schedules defrosts, energizes electric heaters which melt the frost, when the temperature of the coil gets above the point where all ice is melted a thermostat opens cutting the electrical circuit for the heater(s). The defrost cycle continues until the time expires (18-22 minutes). Therefore your problem could be any one of the three elements. Timer, heater, or thermostat.
May 29, 2008 | Refrigerators
Whirlpool Side by Side Refrigerator
hi- there might be a switch inside freezer to turn the ice maker on and off- it will be located on the upper left corner-
Nov 22, 2007 | Whirlpool GS6NBEXR Side by Side...
Fridge not cooloing right
HI I'M HAVING THE SAME PROBLEM THAT YOU ARE...I NOTICED THAT THE FRIDGE DOOR WAS OUT OF LINE WITH THE FREEZER DOOR AT THE TOP...IF THE FRIDGE WAS EMPTY IT WORKED FINE, BUT WHEN WE REFILLED IT,IT WOULD STOP COOLING AGAIN,I THINK IT'S GOT TO DO WITH THE WEIGHT ON THE DOOR MAKING THE DIFFERENCE IN MY CASE...I BELIEVE IT HAS SOMETHING TO DO WITH THE SWITCH AT THE TOP, INSIDE THE FRIDGE THAT OPERATES THE LIGHT AND THE TEMP CONTROL IN MY CASE.TRY OPENING THE DOOR JUST A LITTLE SO THAT YOU CAN SEE IF THE SWITCH IS BEING FULLY CLOSED...I THINK I'M GOING TO HAVE TO ADJUST MY FRIDGE DOOR UP TO GET IT TO DO THIS FOR ME...WILL LET YOU KNOW IF THIS WORKS!!!!!
Sep 09, 2007 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
168 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
