Mitsubishi WS-55411 55" Rear Projection Television Logo
Posted on Jan 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No red - Mitsubishi WS-55411 55" Rear Projection Television
Anonymous
Level 2:
New Friend:
  • Expert 75 Answers
  • Posted on Jan 18, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
75
Questions
0
Helped
12250
Points
237
More then likely the red gun (bulb) had burnt out. It will need to be replaced. Unfortunately its not an easy process and should be done buy an certified technician. Contact your local TV repair shop for a quote.
Thanks
Dustin
Red paint code for Suzuki 1974 rv90
colour code colours
YMU MICRO METAL RED
19A CANDY ANTARES RED
28V MARBLE ITALIAN RED
6CS ROUGE RED
U7D ROYAL RED
Y0R CANDY FLARE RED
Y6B HAIRLINE CHROME RED
Y9B CHROME RED
YHL CANDY SONOMA RED
YKS FIERY RED
YMU MICRO METAL RED
YU7 PEARL CRYSTAL RED
You should have the colour code somewhere on frame of bike. Hope this helps.
4helpful
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
2helpful
2answers
Some keys on the keypad are not working, like the del key and the letter p
Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653
6helpful
3answers
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Red
Sorry, your red crt (picture tube) is bad, last time i called sony they were no longer available. Have your tv guy turn down the red drive on your screen control (inside the tv chassis , you should not do this !) it may stop the bright red for a while.
Sony WEGA TV Red color wont display at all.
as other color are ok(blue&green)& no red colour.please check as follows. 1 check supply to red video transistor. 2 check for loose crt base. 3 check for loose connector 4 check components related to red video ckt.& cathode ckt. 5 check for red signal is coming to red video ckt. 6 check red cathoe voltage. 7 signal processor ic.
Picture red
red screen is due to problem in red video circuit. please check 1 supply to red video ckt. 2 crt base loose. 3 components in red video ckt. 4 loose contact in red cathode ckt in crt base. 5 red video transistor. 6 signal coming to red video from signal processor. 7 signal processor ic. as per schematic check web site www.serviceinfo.com good luck.
Red picture
if picture is red & DARK PLEASE componemts of red cathode ckt 1 red video supply 2 ckt & loose contact near red ckt 3 red signal is coming to red video from signal processor 4 crt base loose 5 red signal processor ic. schematic www.serviceinfo.com good luck
6helpful
2answers
Red screen
how to lower the red screen voltage?
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
