Question about Samsung Yepp YP-P2 Digital Media Player
Charging problem Im having trouble with the fact that every time i charge my Samsung p2 into my computer it says fully charged but yet when i unplug it my p2 says low battery. I've tried everything but nothing will work what should i do??
    Sergeant:
  • 250 Answers
Hello lil ronaldo,
It sounds like the internal battery pack may be failing. The rechargeable batteries commonly used in MP3 players last a long time but they do eventually fail and when that happens the battery will fail to properly hold a charge. It may come up to full voltage when you attempt to charge it but will quickly run out of power when removed from the charger. This sounds like what is happening based on your description.
I would recommend contacting Samsung to get battery replacement service. You can call them at 1-800-SAMSUNG (726-7864) or use their online service request tool. If the unit is outside of the original manufacturer's warranty there will probably be a charge for the service.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jul 16, 2008
My son had the same problem with his rca mp3 last night. As it turned out, the usb charger he was using looked like the one that came with his player, but it was in fact one that came with his brother's player a different model. We have two of them so my son thought the charger would work with his mp3 as he had misplaced his.
When I used the charger from the other two players, although they look like the same, it would say the battery was fully charged and when unpluged it would read low battery. I tested both usb cords and got the same response.
Then when I used the correct usb cord that came with the rca player everything was fine. So it seems that even though the connecting end fits in the player and looks the same, if it did not come with the player it would not charge it. This is true of several other devices we have. So check your usb charger cord. Make sure it is the one that came with your device, and also check to see that it is not damage.
hope this helps, as it did the trick for my son's mp3 and saved us returning it to the store.
Posted on Jan 06, 2009
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
Samsung p2 won't turn on
the battery seem to be bad replace the unit.
Jul 09, 2008 | Samsung Yepp YP-P2 Digital Media Player
My Yp-p2 does not turn on. When I try, it blinks red.
it locked just slide the hold swith above the pwer button *facepalm*
Feb 19, 2010 | Samsung YP-P2 Digital Media Player
When I plug my yp-p2 to charge it it lights up and shows it's charging. When it's finished and I unplug it, it will not turn on.
Connect it to your PC and then try to charge it for 5-6 hours as it is the average charging time for mp3/4 player it will help alot.!
Thanks :) Please rate.
Jan 03, 2010 | Samsung Yepp YP-P2 Digital Media Player
My samsung p2 will not turn on...
battery can fully charged but if contacts of the tray are dirt than no current can pass through. firstly check contacts, switch showing that it is come out, after pushing it in, also check for polirities of batteries.
Mar 25, 2009 | Samsung YP-K3 MP3 Player
YP-T9 constantly charging?
if you recharg it too much it could be wearing down, I'm guessing. unless oyu just got it.. you should take ti back because that's just messed
Jul 02, 2008 | Samsung Yepp YP-T9 Digital Media Player
HEYY. okay. mine did the exact same thing but i took a toothpick and pressed the "reset" button on the back of the player. after i hit it once or twice, i tried turning it on and it worked.
Mar 18, 2008 | Samsung Yepp YP-P2 Digital Media Player
P2 won't on!
I called tech support because i was having the same problem....on the back, there is a reset button (YP-P2JAR at least) you must hold the reset button for 30 seconds, then turn it on. Worked for me!
Battery Life???
sometime you need to discharge the battery completely those charger are electronic they dont charge properly if the battery not fully discharge cheers
Jan 18, 2008 | Samsung Yepp YP-P2 Digital Media Player
Samsung Yepp YP-P2 Digital Media Player Logo
109 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
