Tv protection after power cut my tv says protected, how do i fix this without needing to know about electronics or buying things. MY TV IS A GRUNDIG T55-1010
  • 372 Answers
The set is expecting a pin number to be inserted.
If you dont know or cant remember pin do this.
Do this to the letter it should sort out your problem.
Posted on Jul 16, 2008
Unblock locked grundig tv t55 1020
try 0000 reset
Other wise
This is how its done but you will need A repair shop to do it.
Place set in to protect by entering any sequence of numbers 3 times,
Connect a 390ohm resistor between w129 (ground) and pin 56 of the micro,
Press button 7 on the remote for a minimum of 6 secs.
And thats it unlocked.
Sorry its not a simple fix.
Apr 21, 2014 | Grundig Televison & Video
Tv does'nt Pwr up
will need to be taken apart to figure problem. check fuses and for any burned component. possibly if no high voltage.. not worth fixing.
Oct 05, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Tv cut off
from the video clip it seems your tv has gone into protection ( the power supply is tripping due to a fault in the tv
you ill need to take it to be repaired
Jun 03, 2013 | Televison & Video
What is the difference between a regular power strip and a surge protector?
A power strip is what's used for plugging in multiple appliances to one outlet. A surge protector is different in that it is designed to prevent electrical surges from too many things plugged in, bad weather or lightening. Usually things like air conditioners with heavy motors are plugged into surge protectors.
Jan 31, 2013 | Electronics - Others
Audio static when using any power switches in house
You could try a power strip that has voltage spike protection in it, but to tell you the truth, TVs and other electronic devices are supposed to accept such interference without malfunctioning.
Dec 12, 2011 | Sharp 32SC26B 32" TV
Both of my tv's died yesterday. My apex wont turn on anymore an the panasonic has no picture. Whats wrong.
As an electrician, when someone loses more then 1 item of electronics in 1 day, its almost
always traceable to a nearby lightning strike, accompanied by a lack of surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360. Surge protection can
be provided by the consumer at the power strip (a good one with builtin protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house protection, or per-circuit protection at
the breaker box, where a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed), other than renters insurance or homeowners insurance.
If desperate, you could try replacing the entire power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Aug 15, 2011 | RCA F36450 36" TV
2 tv's when I try to cut them on they make a clicking noise
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here, a common fault is PSU, but part must be tested before replacement.
Appliance parts, electronics parts & more from
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Mar 15, 2009 | Toshiba 27A62 27" TV
Tv turns on and turns off after 5 seconds
jim if know how to soldering iron ,resolder your tv especially the power supply
Jan 26, 2009 | Televison & Video
I have a Grundig tv WF70-3020, when turned on this afternoon, the
The installer code is 3477, switch off the tv and unplug from the mains and leave for at least 30 minutes before trying this when you switch on your tv it will ask you for a pin code - use the installer code and it works just fine :)
Jan 25, 2009 | Home Security
Televison & Video Logo
358 people viewed this question
Top Televison & Video Experts
