Question about E-Machines eMachines Monitor E15T4
Monitor The picture on our monitor will somethimes get distorted so that the edges of the picture is off the screen. When we turn the computer off 2 or 3 times it will eventually right itself. It sometimes happens while we are working online too. I have tried to adjust the picture using the menu but it hasn't worked yet. Any ideas?
Adjust the pixels. Right click on desktop, properties, appearences, advanced and there should be a slide bar to adjust your pixels. Make them larger, ex. 1440X900 instead of 680X400
Posted on Aug 18, 2008
Monitor distorts colors and goes out of sync horizontally after 15 min
they dont last forever... time for replacement as most are not user-serviceable..
Mar 08, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
I went on vacation and turned off my computer (the
mcdevito75 here, Your Monitor could be bad, (blown out) a monitor is just like a lite bulb. start your computer verify fan is on, verify monitor is on with on off switch on monitor, press shift key on keyboard maybe your computer is on stand by or hybirnation, also click the mouse at the screen left click and right click to bring picture to screen, if picture on monitor ok, if not press AUTO on the monitor, this brings back factory settings to your monitor. If all this fails, bring your monitor to a Radio Shack, Staples etc. for testing.
Jul 21, 2010 | HP Pavilion a1210n (ED895AA) PC Desktop
Will not hold picture - picture distorted
If your monitor will hold pictures and your the screen is distorted, this is a sign that the picture board on your monitor is bad and will need to be replace in order to fix the problem.
Replace the picture board on your monitor to solve the problem.
Take care.
Jun 25, 2010 | IBM G54 Monitor
Whole screen pink and edges distorted green its on my dell insiron 6400 laptop
check the connctions on your monitor. I had this problem on my monitor for 2 months and it started shortly after I cleaned my desk so I thought maybe I had accidentally pressed a button. I found out later that a wobbly connection to the monitor gave faulty connection info to the screen so I just touched it today and it went magically white. Please try it before attempting anything else!
May 13, 2010 | ASUS VW222U Monitor
Left hand Edge distortion on screen.
change monitor frequancy from grafics properties
only 60 Hz
Nov 11, 2009 | Dell P793 17" CRT Monitor
I bought a 1600x900 monitor and now pictures are distorted
Your screen's ratio is oriented to playing wide screen formatted movies. Set your screen resolution to a ratio that's more or less 2 to 1 and you'll have a more realistic depiction of people on photos.
Aug 16, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Distorted shrunken picture
hi
reduce the resolution to a bit lower and the refresh rate to a nominal 60hz and things should get back to normal
my hunch is u r using a slightly high resolution and refresh rates
but before that try the buttons on the monitor to see if expanding the image sideways or top and bottom would help initially
cheers
pls rate if this was any help
Mar 31, 2009 | NEC MultiSync FE700 17" CRT Monitor
Screen image display distortion
Hello.
What you are reporting is a problem in the pincushion circuit in the horizontal section of your CRT monitor. Usually this is from an electrolytic capacitor that is no longer willing to play nice with all the other components.
It is repairable, but get an estimate first. If the repair bill appears to be around $100, you would be better off to put a few more dollars with that and buy an LCD TFT monitor.
If you are quoted $25 or $30, it is probably worth having repaired. Just keep in mind that these older CRT monitors have age on their components, and once repaired, it will still be an old monitor.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
I hope this helps.
Nov 06, 2007 | Apple Multiple Scan 1705 Monitor
Screen Distortion at certain Refresh Rates
Have you connected the laptop to another monitor and use the same refresh rates that cause the distortion? If the distortion appears on a different monitor, then I would have your laptop examined by a pc engineer, but, if the distortion only appears on the 997DF monitor, I suggest having the monitor checked at a repair shop, also, have you tried connecting the 997DF to a desktop PC, and use the same refresh rates?
Jun 16, 2007 | Samsung 997DF 19" CRT Monitor
E-Machines eMachines Monitor E15T4 Logo
55 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
