Question about Epson Stylus CX6000 All-In-One InkJet Printer
Changing Ink Cartridges
Epson Stylus CX-6000
My Epson Stylus CX 6000 showed low ink
I replaced all the cartridges & It stil gives the message
" Replace ink cartridges"
  • micknmare Aug 01, 2008
    Thanks for your help. After many times of taking out the Epson
    cartridges and I mean many times, and after reinserting & cleaning the chips with alcohol, it began to print again.
    Most grateful!
    Micknmare
  • Anonymous Jan 31, 2009
    i printed a sheet nothing on it
    Novelist:
    Scholar:
  • 125 Answers
I'm assuming you are using originals. I would suggest you taking the cartridges out and re-inserting them. If you are using refilled cartridges and you used the cartridges to almost empty then probably the chip may have short circuited rendering the chip useless. If you bought remanufctured cartridges I suggest you ask them for replacements. This isn't really that high tech but I hope this helps.
Posted on Aug 01, 2008
I just replaced all my inks and it is still telling me to replace my cartridges i also turned it on then off
  1. Open the scanner.
  2. Press the cp_button_14.gif Stop button to move the cartridges to the replacement position.
    Caution: Do not move the print head by hand; this may damage your all-in-one. Always press and release the cp_button_14.gif Stop button to move it
  3. Open the cartridge cover.
  4. Press down all the ink cartridges until they click into place to make sure they are properly seated.
  5. Close the cartridge cover and push it down until it clicks into place.
  6. Close the scanner.
  7. Press the cp_button_14.gif Stop button to begin charging the ink. This takes about 2 minutes.
    When the On light stops flashing and remains on, ink charging is finished.
    Caution:
    Never turn off the Epson Stylus CX while ink is charging or you'll waste ink.
    If the ink light flashes, press the cp_button_14.gif Stop button and press down all the cartridges securely.
    If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
    If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 22, 2011 | Epson Stylus cx7450 All-In-One InkJet...
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Using knockoff ink, Epson allows repalcement only
Please do not for a minute beleive that Epson endorses or allows the use of refilled ink cartridges or third party cartridges. It is just not true.
Consider this:
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 19, 2010 | Epson Stylus CX4800 All-In-One InkJet...
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
My epson stylus cx6000 printer keeps showing -(install the ink cartridges) and I have already put in new ones. The code is E-02.
f you have just installed a new cartridge and you still see an ink related error message, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Stylus CX is turned on.
  2. Check the photo viewer screen to determine which cartridge is incorrectly installed. Then do one of the following:
    • If printer shows the ink cartridge is expended, press the cp_button_6.gif Start button.
    • If the printer shows the cartridge is low on ink, press the Setup/Utilities button. Press the cp_button_41_er.gif or cp_button_42_er.gif button to select Press Start to change cartridges. Then press the cp_button_6.gif Start button.
  3. Press the cp_button_6.gif Start button again.
  4. Lift up the scanner, then open the cartridge cover.
alert_caution.gif Caution:
Never attempt to open the cartridge cover when the print head is moving. Wait until the cartridges have moved to the replacement position.
  • Press down all the ink cartridges until they click into place to make sure they are properly seated.
  • alert_note.gif Note:
    If a cartridge is properly seated already, you may not hear a click.
  • Close the ink cartridge cover and press it until it clicks into place.
  • Close the scanner.
  • Press the cp_button_6.gif Start button. The Stylus CX charges ink for about one minute and displays Charging Ink on the photo viewer screen until charging is finished.
  • alert_caution.gif Caution:
    Never turn off the Stylus CX while the Charging Ink message is displayed or you'll waste ink.
  • Press the Setup/Utilities button to return to the previous mode, if necessary.
  • Aug 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    Epson Stylus DX 8400
    It sounds like you have incompatible cartridges for your printer... Some folks have reported that disabling the Status monitor and turning the printer off/on, plus rebooting the computer can solve this but that's just something I've heard.
    You may want to double check with the ink supplier that they have provided the correct cartridges for your DX rather than a CX model.
    May 17, 2009 | Epson Stylus DX8400 All-In-One InkJet...
    Epson stylus cx 7400
    Epson includes step-by-step instructions on changing the ink cartridges in the Printing Preferences menu:
    Click the start button and open the Control Panel.
    Right click Printers and select Printing Preferences.
    Click the Maintenance tab.
    You should see a button that says Ink Cartridge Replacement.
    Just follow the instructions and it walks you through it.
    Sep 19, 2008 | Epson Stylus Multifunction Inkjet Printer/...
    Help with Epson Stylus CX 6000
    Hi Open the cover then switch on the printer and then off from the mains when the cartridges are in the middle. Hope this helps!
    May 23, 2008 | Epson Stylus CX6000 All-In-One InkJet...
    I NEEED DRIVER OF INSTALATION OF IMPRESORA STYLUS CX 6000 PLIS MI MAIL IS marsa78_eva@yahoo.com.mx
    Jan 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
    Epson Stylus  CX6000 All-In-One InkJet Printer Logo
    253 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
