Question about Sony Video Cameras
Descending and play problem
When I inserted the tape it descended and a message of reinsert the tape came on the screen. When opening the case again the case would not open to reveal the tape. Eventually it did reopen but would not descend again.
Same thing happened to me and to fix it i dropped from like 2 feet off the ground on to carpet and it made it go back in and it made it work
Posted on Jul 15, 2008
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
My hp pavillion tx1320us is powering up but the screen remains black
try to turn off the laptop. Remove the cables and battery on the pc. Press and hold the power button for 8 secs. Then reinsert the cables and battery on the pc. Turn on the laptop and check if the screen still black. If it is, make sure that the monitor power light is on. Otherwise, there might be a problem on the video card. If you know how to reseat a video card, go for it and here is the step by step, instructions:
Turn off the laptop, remove the cables and battery, remove the screws at the bottom part 4 corner sides, remove the hard drive, remove the optical drive, then remove the video card and reinsert it. Then reinsert the other peripherals in descending order.
If still did not work, call HP and have your video card replaced...
Jul 27, 2010 | HP Computers & Internet
Reinsert cassette - After inserting a cassette the on screen message reads as follows "reinsert cassette" a further message C:31:23
when ever to get this kind of message just try to fwd the tape mannualy, or just make sure tht when u are rew. the tape dont rewind tht completely....
Jan 04, 2010 | Sony DCR-TRV285E Digital-8 Digital...
Volume keeps descending to zero. it plays for a
It sound like a faulty volume switch, it could be the one on the radio or the one on the steering wheel.
Nov 27, 2009 | Car Audio & Video
HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
Mar 07, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
What are Rappel devices (descenders) and what kinds are there?
These devices are friction brakes which are designed for descending ropes. Many belay devices can be used as descenders, but there are descenders that are not practical for belaying, since it is too difficult to feed rope through them. Figure eight Sometimes just called "eight", this device is most commonly used as a descender, but may also be used as a belay device in the absence of more appropriate equipment. It is an aluminium (or occasionally steel) "8" shaped device, but comes in several varieties. Its main advantage is efficient heat dissipation. A square eight, used in rescue applications, is better for rappelling than the traditional 8. Because of the "ears" or "wings" on the rescue 8, there is less chance of forming a girth hitch whilst rappelling very quickly. A figure eight descender Figure eights allow fast but controlled descent on a rope. They are easy to set up and are effective in dissipating the heat caused by friction but have a tendency to put a twist in the rope. Holding the brake hand off to the side twists the rope, whereas holding the brake hand straight down, parallel to the body, allows a controlled descent without twisting the rope. Because of the many bends it puts into the rope, an 8 descender can wear a rope quicker than a tube style belay/rappel device. Many sport climbers also avoid them because of the extra bulk an 8 puts on the rack. However, many ice climbers prefer to use the 8, because it is much easier to thread with stiff or frozen rope. Rescue eight A rescue eight is a variation of a figure eight, with "ears" or "wings" which prevent the rope from "locking up" or creating a girth hitch, thus stranding the rappeller on the rope. Rescue eights are frequently made of steel, rather than aluminium. Rack This consists of a 'U' shaped frame, attached to the belayer's harness, into which snap multiple bars that pivot from the other side of the frame. The rope is woven through as many of the bars as are required to provide sufficient friction. This arrangement allows for variations in rope diameter and condition, as well as controlled rate of descent.
Dec 01, 2008 | Black Diamond Super 8 Belay Device
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Reinsert tape message
I got the dreaded reinsert tape message today and i thouht that my video taping days were over. i then made my way to this page and saw this. whack it three or four times and it will work. at first i thought what a load of crap but i tried it anyways... being really mad at the time, i showed my camera no mercy. i took out the tape and gave it 4 hard hits with my palm, put the tape back in and it worked. thanks alot, this works
i
Aug 11, 2007 | Sony CCD-TRV138 Camcorder
Video Cameras Logo
66 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
