Question about Apple iPhone 3G
How to program a tr-2600a scanner? - Apple iPhone 3G
NECESITO CONOCER EL MANEJO DE HT 2006A ó
CONSEGUIR EN MANUAL DEL USUARIO.
SOY .: JORGE A ODERIGO LU2DWP
mail joderigo@yahoo.com.ar
muchas gracias
Posted on Aug 01, 2008
  • joderigo Aug 01, 2008
    ´osolo el manual del usuario en ingles ó español
THE SCANNER SHOWS p0 708
code p0708 refers to transmission range (TR) switch/sensor--high input===causes --wiring short to positive--TR switch/ sensor--ECM/TCM
replace the TR sensor /switch first and then check the TCM for operation
Aug 14, 2014 | Cars & Trucks
How do you find what check engine code is up without an scanner?
then scanner will show a code (po**** or p**** or a series of dots and dashes) You then have to refer these codes to a manual for interpretation of the faults. ie code on scanner p0707 . refers to TR sensor switch and a number of possible causes that will cause this code.. With out a scanner you cannot read any codes
Dec 24, 2013 | 1998 Plymouth Grand Voyager
Want to locate censor p0705 on a 2006 suzuki forenza
DTC P0705 - Transmission Range (TR) switch circuit malfunction (short to power supply)
DETECTION CONDITION
• Two or more range signals are input from the TR switch for 12 s or more.
Diagnostic support note:
• This is a continuous monitor (CCM).
• MIL illuminates if TCM detects the above malfunction condition in two consecutive drive cycles.
• PENDING CODE is available.
• FREEZE FRAME DATA is available.
• AT warning light illuminates.
• DTC is stored in TCM memory.
POSSIBLE CAUSE
• TCM malfunction
• Short to power supply in wiring harness between TR switch terminal A and TCM terminal 1D
• Short to power supply in wiring harness between TR switch terminal E and TCM terminal 2C
• Short to power supply in wiring harness between TR switch terminal D and TCM terminal 2B
• Short to power supply in wiring harness between TR switch terminal G and TCM terminal 2E
• Damaged connector between TR switch and TCM
• TR switch malfunction
Inspect swtich harnesses and test with OBD scanner reader tool.
Sep 30, 2011 | 2006 Suzuki Forenza
1. What is the average life span of a marine radar? 2. Where is the TR cell located? 3. How to test a marine Radar?
The life span of the radar depends on its use.
There are consumables inside, mainly the Magnetron and the scanner motor assembly, the life of which depend on running hours. The life of Display is high compared to these two.
The TR cell is located in the wave path before the receiver(detector/MIC)
Most Radars have a menu function for 'Test".
Aug 05, 2011 | Furuno 1715 LCD Radar System GPS Receiver
Need installation instructions to replace SW-6538, range sensor, for 2005 ford focus
only have 2002 right now
SECTION 307-01: Automatic Transmission/Transaxle 2002 Focus Workshop Manual
IN-VEHICLE REPAIR Transmission Range (TR) Sensor Removal
  1. Disconnect the transmission range (TR) sensor electrical connector and the selector lever cable.
  1. NOTE: Failure to hold the shift lever while loosening or tightening the manual shaft lever will transmit rotational torque to the TR switch and shift mechanism.
    Remove the TR sensor (automatic transaxle removed shown).
    1. Remove the manual control lever.
    1. Remove the bolts.
Installation
    Install the TR sensor (automatic transaxle removed shown).
    • Loosely install the bolts.
    • Install the manual control lever.
  1. Using the special tool, align the TR sensor and tighten the bolts.
  1. s2y~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use air tools on this bolt. Hold the manual control lever while tightening the manual control lever bolt, failure to the manual control lever shaft could occur.
  1. s2y~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Check the manual control lever is in position "3" same as "D" position.
    Adjust the manual control lever to TR sensor "D" position.
    1. "1" Low 1
    1. "2" Low 2
    1. "D" Drive
    1. "N" Neutral
    1. "R" Reverse
    1. "P" Park
    • When in position "D" the marks on the manual control lever line up with the marks on the TR Sensor.
  1. Connect the selector lever cable and the TR sensor electrical connector.
May 23, 2011 | Ford Focus Cars & Trucks
Alpine INA W900 and pac tr7 installed.
Connect your
Alpine INA-W900 to your iPod via Bluetoot and do the setting from your Alpine dash receiver as per instructed
May 31, 2010 | Universal Remote Control Pac Tr 7...
Impossible d'installer canoscan D66OU sur VISTA
Vous pouvez essayer d´ínstaller le programme "vuescan". Ce programme fonctionne avec mon vieux scanner. C´est un probléme trés important puis Vista est incompattible avec nombreux scanners.
Apr 01, 2010 | Canon CanoScan D660U Flatbed Scanner
I need a user manual
i provide you user manual for NX-542 in portable TV,
Product MPN
MPN NX542
Key Features
TV Type   Portable Screen Size   13 inch Display Type Color
Other Features
Remote Control   With Remote Control AV Inputs Composite 1 Sleep Timer   With Sleep Timer Antenna Capability   External
Physical Characteristics
Power Source DC Adapter, AC Adapter Type Portable Display Type Color Screen Size   13 inch Depth 14.75 in. Height 14 in. Width 14.75 in.
Miscellaneous
UPC 840005000977 Product ID 77523163
i hope this is helpful to you.
Thanks,
Dec 04, 2009 | Naxa Electronics NX-542 13 in. Portable TV
Please I need to download the driver for mercury scanner 1200cu+ for a Windows vista
i lost my drives for my scanner Mercury Flatbed Scanner how do I download it, please it is urgent
Nov 20, 2009 | Mustek Be@rPaw 1200CU+ Flatbed Scanner
Connecting NAD 2600a amp.
Never connect incompatible connections. Speaker outputs are for speaker inputs. Period.
The various inputs on this or most any amp are for Line Level signal with the exception of anything explicitly labeled "PHONO" as that would be for a non-preamplified turntable ONLY.
From what I have found online, Lab-In was a NAD feature that restored the frequencies that were rolled off when turntables were being used in the (assumed) preamplifier that fed this amp.
http://web.295.ca/~peak//audio.html
"NAD belleived at the time that practical PHONO stages and the preamp and power amplifier stages be rolled off at subsonic frequencies to prevent subsonic wow and flutter from Turntables and supersonic frequencies (EMI/RF/Radio) signals from getting into the system in the first place. Their notion was that if your ears cannot physically hear it, then why amplify it. For the PURIST, there were a set of LAB IN amplifier inputs with more extended response called "LAB IN" inputs"
Use the Lab In's UNLESS you have a turntable source.
Aug 22, 2009 | NAD Audio Players & Recorders
Apple iPhone 3G Logo
128 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
