Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi vs 5043 no picture
U can here it come on and the green light comes on and there is sound but no picture at all.
  • Anonymous Sep 11, 2008
    My Mitsubishi VS-5043 television turns on but my screen is black. I get no picture.
    Genius:
  • 2,920 Answers
Have the tubes checked out you may have a loose connection
Posted on Aug 25, 2008
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
50" Mitsubishi
Check the 5 volt pico fuses on the center board. F9A05 is most likley open. This would indicate bad convergence amps. The two Convergence amps and fuse should be replaced.
Josh
Mar 02, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi 50 in vs-5043
Needs convergence circuit O/h==replace convergence IC's & any damaged/over-heated resistors.re-align as needed.
Oct 01, 2007 | Mitsubishi VS-50502 50" Rear Projection...
Mitsubishi vs-5051
First you can safely take off back and look for Screen controls&Focus, Gently turn up the 3 screen controls this will add light to picture, but you need to evenly turn up, the 3 colors are red, blue, green. the other 3 knobs are for focus. Do not turn them if you do you will need to realign the focus also. And if this doesn't help then there is a high voltage capacitor leaky in the flyback area.
Sep 14, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs-5043
Look for short on Green CRT board.
Aug 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Jan 06, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
139 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
