Question about Cameras
Lens cover On my Canon Poershot SX100, the lens will not completely close/open. It's very slow to do either. There is a very small substance that I believe is keeping it from functioning properly. Can you help tell me where I can send it or take it to get checked out?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey pkg414,
You could bring the camera to a Geek Squad® precinct in a Best Buy™ store and they should be able to send it out for service, or you could contact the manufacturer and they should have a list of authorized service technicians in your area. I will also says if the camera is less than a year old the repair will probably be covered under manufacturers warranty and be no charge to you. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 17, 2008
I lost the cover for thecanon date battery
You can order one from http://uscamera.com/cd4-0816.htm
May 12, 2010 | Canon PowerShot SX100 IS Digital Camera
I have a canon powershot sx100 IS the lens is
Here is a site that discusses things you can try to fix this for free. They do a much better job than I could, and they let you know the risks and steps to take, in order. Try this first, you might get lucky- they say 50% of stuck lenses or lens errors can be fixed.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Don't worry, this is a huge problem with extendable lenses, due to their construction with small, plastic gears that are easy to break with a bump or fall, or obstruction while extending.
Apr 18, 2010 | Canon PowerShot SX100 IS Digital Camera
Canon a710 IS -- can't reinstall lens cover ''flippers''
Sophisticated digital cameras are not consumer repairable. Good luck.
Aug 22, 2009 | Cameras
I have the canon sx100 is, it dropped and now the shutter eye won't open
If only the shutter eye is not opening but the lens is extending properly, then you will need to remove the fron shutter frame and review it.
It may be that one (or both) springs that open the lens protector are loose, or the plastic tab that allows to open/close the lens protector is broken.
If the lens does not extend when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solutio is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Jul 18, 2009 | Canon PowerShot SX100 IS Digital Camera
"Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
Apr 19, 2009 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
"lens error" error message
Got to the menu in the camera, click on the lens sixe you wish to use. Then take some pictures, try changing the sizes ans see the diffetrent results.
Also it might be that you did not open the lens cover completely before you take the picture.
Take care
Artgirl
Jul 08, 2008 | Canon PowerShot SX100 IS Digital Camera
Lens error
sir,problum is ur lens unit,some mechanical or dislocations,gears this is repairable u try ur local service center
Apr 11, 2008 | Canon PowerShot SX100 IS Digital Camera
Cameras Logo
67 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
