Question about Lexmark X5470 All-In-One InkJet Printer
"color cartridge replacement required"
After refilling a Lexmark 29 cartridge the printer still wants a new cartridge and says " color cartridge replacement required" Is there a way of sorting this out?
best regards
fred evans
    Genius:
  • 2,035 Answers
This is common problem with lexmark cartridges they detect refilled cartridge you need to clean the copper contacts of the cartridge and then insert it if it still shows " color cartridge replacement required" message then you need to buy original color cartridge.........
Posted on Jul 16, 2008
  •  Terri Popiel
    Terri Popiel Nov 02, 2013
    It has an orginal cartridge in it which I refilled with ink and it still doesn't work. Cleanining didn't help either.
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    My lexmark X5410 will not accept the black and colored refilled ink cartridges from walgreens. It keeps reporting that the right cartridge is missing.
    If you have refilled the cartridges 28 and 29, it's pretty normal that your printer won't print. Those cartridges are not for refill (they can be refilled, but won't work once the printer says they are empty). If you have refilled a 28A and 29A and it doesn't recognize the one of the cartridges, try removing them and clean the electric contacts with a dry cloth. Put them back in. If that doesn't help, I suggest you buy a new cartridge.
    Apr 11, 2010 | Lexmark X4530 InkJet Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Refilled ink cartridges at Walgreens, printer won't recognize
    Hello!
    28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill.
    You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
    If you find my answer helpful, please vote. Thank you!
    Aug 05, 2009 | Lexmark X2550 All-In-One Printer
    Refilled cartridge, still says it needs to be replaced...
    If you let the cartridge run totally dry then they need to be reset or replaced, I have tried purchasing reset software myself and found then to be a waist of money as they do not reset the cartridge at all. Do yourself a favor and replace the cartridge and remember to top up the cartridges before they get half empty.
    May 08, 2009 | Lexmark X2600 InkJet Printer
    Lexmark 5070 printer
    Hard to tell...There are other issues which could contribute related to the printer itself, etc.
    But I will say in my experience often refill kits for ink cartridges don't work if you allow them the cartridge to run bone dry. Maybe the internal components become hard and won't re saturate with new ink, not sure. If new cartridges work; and the refills don't I'd say there may be a problem with them.
    Jul 22, 2008 | Lexmark X4270 All-In-One InkJet Printer
    Using refill cartridges
    That is because they cannot e refilled. The ones you get with your printer ( 28 & 29) are what Lexmark calls "return program cartridges", which means they are for one use only.
    I suggest you buy other cartridges that can be refilled. Those are either 28A or 34 (black cartridge) and 29A or 35 (color cartridge).
    Here is a link to Lexmark's site, where you can see the list of cartridges that are compatible with your printer.
    http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=Lexmark+Z845
    Hope that helps!
    Jun 05, 2008 | Lexmark Z845 InkJet Printer
    Refilled color cartridge for lexmark Z845
    The only work around to this is to use two catridges(2 color and 2 black and white). The reason is the printer has a mechanism to check if the same catridge is being used again. SO when you have two cartridges when one is finished refill the other and use and vice-versa. This way you will be able to refill and use for ever without any problems..
    Regards,
    Eagle338.
    Mar 13, 2008 | Lexmark Z845 InkJet Printer
    Lexmark 29 ink cartridge
    For the record the lexmark 29 (18C1429) cartridge is a one time use cartridge (return program cartridge). If you want to get a Lexmark 29 cartridge that you can refill you must buy the 18C1529 Lexmark 29 cartridge. This cartridge can be refilled and reused. The catch, you can only buy this cartridge from Lexmark.com new. I know of one company that sells the remanufacture Lexmark 29 (18C1529) yourinksolution.com.
    Feb 07, 2008 | Office Equipment & Supplies
    Lexmark X5470 All-In-One InkJet Printer Logo
    1,123 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
