Question about Kodak i 280 Path-Through Scanner
I280 won't scan!
Hello, I have a Kodak i280 running in on a standalone XP machine, and all the scanner does now is give an error that says "Check the kds.log" file. When I check it, it gives me:
00008 123607420 kdsprot 4489 31 S5 SCSISCAN ImageCalibration(): 89
I can never get the machine to scan anymore. Any suggestions would be greatly appreciated!
    Problem Solver:
  • 8 Answers
ImageCalibration means the cameras don't get enough light during their self test.
Please check the following points:
Are both lamps on or one lamp in case you have a single page scanner?
Are the imaging guides (the clear sheets above the cameras) clean?
Are the little white tags on the imaging guides present?
One tag on each imaging guide.
Without this small white tags the cameras are not able to check themself.
For emergency you can apply a small white paper or white insulating tape instead of missing tags to test the scanner.
If the lamps are light, both tags are present please calibrate the scanner with the kodak calibration sheets. You will find the calibration menue in the scanner validation tool. You can get this tool from the Kodak home page.
Posted on Jul 15, 2008
My Canon P-150 keeps giving me a "double feed" error and won't scan.
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer. Then reinstall software again
Jun 07, 2012 | Canon imageFORMULA P-150 Personal Document...
Problems with coolscan3 and AMD64 machine
hi, please find enclosed a link showing nikon scan compatibility with different operating systems if you are using xp 64 bit or 32bit the table is showing that your version of nikon scan is not compatible*VyJi&p_accessibility=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAmcF9wcm9kcz0yNSwzMSZwX2NhdHM9MjQxLDE3OSZwX3B2PTIuMzEmcF9jdj0yLjE3OSZwX3BhZ2U9MQ**&p_li=&p_topview=1 hope this helps
Aug 19, 2007 | Nikon Coolscan III Film Scanner
Kodak i1440 scanner error 4769
Hi the error isnt one that corresponds to a scanner error number , you should run the scan validation tool and get the error from that , having said that check the image guides are clean and undamaged this is a major cause of faults
Sep 09, 2011 | Kodak i1440 Pass-Through Scanner
I have 6 identical new PC's running Windows XP SP3 with Kodak i1210 scanners. 4 of them are running fine and scanning fine. The two giving me an issue are scanning fine as well but they are scanning...
Please check if the disk where you are saving has enough space. Defrag the drive for better results. If you are connecting the scanners trough an USB cable, try replacing them. Also check if the file format is same. If you have chosen to scan BMP or TIFF uncompressed or Color, the file size may be too big. I presume the other two PCs are free of virus.
S. Mohan
Aug 09, 2010 | Kodak i1210 Pass-Through Scanner
Bandings on Scaned Images.
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. perhaps problem with scanner drivers of the printer. Try to install the latest version of Printer software from on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from all the best.
Jun 13, 2009 | Kodak ESP 5 Printer
Microtek ScanMaker 8700 - 'kdsinput internal error'.
try this:
Aug 04, 2008 | Microtek SCANMAKER I900 Flatbed Scanner
Will not scan kodak easyshare 5100
Go to Control Panel
Double Click on Printers and Other Hardware
Double Click on Scanners and Cameras
Double Click on Kodak 5100 AiO
Click Next
Read and follow directions
It ain't rocket science
Feb 08, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Stops scan with the flatbed after tree o forth pages
Try downloading and installing new drivers. You should checkout the machines timeout settings. See if there is a way to set the machine to default settings. Is the machine showing any signs of excessive heat? Is the machine getting time to reset before next scan is sent? The scanners memory may not be clearing to allow room for the new job and just halts. Try a fresh install of the scanner with the newest drivers. Good Luck, Tim
Feb 20, 2007 | Kodak I280
Kodak i 280 Path-Through Scanner Logo
699 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
