Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Wd52525 capacitor replacement
Http://www.fixya.com/support/t661523-wd52525_capacitor_replacement
  • krause67 Jul 19, 2008
    I take it you do not think it is the light engine? Thank you for the your help.
  • lancergsr00 Sep 10, 2008
    Tile or block pattern with no video or OSD. Check D8F00 and D8F01 part # 264P828010, also check C8F26 and C8F29 part # 141P148000 (1 uFD, 25 V) on the FMT PCB (part # 930B924002).
    where can i order the parts for D8F00 and D8F01?? and if @ the place where to ordee it from knows the part no# that you have in here are the same on there records..... email add lancergsr00@yahoo.com
  • 927 Answers
Good day, krause67;
Good question, but I'm not THE FAMOUS "TECHMAN" but I will try to help anyway. The DM board is normanlly on the left side TV looking from the back. It has a shield around it, remove. The caps are big and black, they look the replacements(only ones on board). Here's what says about this issue:
If the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). (LED does not stop blinking after plug in) On the DM
Good Luck, big IRISH. ps hope this helpful!
PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
It is not an easy job, it will take some time but since you have it apart there is another problem that will accure so might as well do this too:
All the parts have location numbers like C8F29 that will tell you what and where these parts are.
Posted on Jul 19, 2008
On / off indicater light keeps flashing red/green and tv will not power on lg du-37lz30
Common problems for most LCD and Plasma tvs sets.The tv power supply board it is the causes and problems,that the board where the tv a/c power cord plug into it.Take the tv aparts and check tv power supply board carefully looking for dying an leaking components capacitors parts.These dying and leaking capacitors parts are alway bulges up onto it tops or puffing up onto it tops.U have all the tools and understanding basic electronic also can do basic soldering work too?Yes.All these dying and leaking components capacitors parts are bulges up or puffng up onto it tops u must have to replace them.Replaces all these dying and leaking capacitors components parts with the same Miro Farad but upgraded all those capacitors parts voltages higher voltages like 5 or 10 voltages higher than those old capacitors components parts u are replacing.By replacing all those old dying and leakages capacitors parts voltages higher 5 or 10 voltages higher.The capacitors parts will with stand heat better than those old capacitors parts was in the power supply board earlier.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 23, 2011 | LG DU-37LZ30 37 in. LCD HDTV
Blinking blue light and blank screen. What repair measures do I need to resolve this??
The tv have a power supply board problems,that the board where the power a/c cord plug into it.U have all the tools and understanding basic electronic also can do basic soldering work too?Yes.Take the tv aparts,check the tv power supply board carefully for dying and soon to dead capacitors components parts,these dying and soon dead capacitors parts are alway bulges ups or puffing ups on to it tops.Replaced all these dying and soon to dead capacitors parts are bulging ups or puffing ups onto it tops.Replaced all these capacitors parts with the same Micro Fared and upgraded the voltages like 5 or 10 voltages higher than those old capacitors parts.Will fixed this tv problems and those capacitors parts will also with stand heat better.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 02, 2011 | JVC LT-42X579 42 in. LCD TV
Wd52525 when powed up set tries turn on. it tries for 2min then powers off with the red led solid at shut off
Most probable a lamp failure, part number according to encompassparts.com is 915P020010.
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=6543337&smodel=WD52525
I have had issues also with the power supply having failed capacitors, tops of caps will bulge up rather than be flat. The most common failure is a popped lamp or defective lamp. Inspect the anode of the lamp, it may have fractured or is swollen at the base.
I buy lamps on line from a company called niosales NEIlamps and electronics.com
Jul 12, 2011 | Televison & Video
The monitor has bad caps, how do we replace them/get them replaced?
damage capacitors must be replace with the same rating/value of capacitor.they are rated as uf/volts ex 50uf/25 volts.use a soldering iron and desoldering pump to remove it from the PCB board..
Dec 24, 2010 | LG W2252TQ-PF 22" Monitor
AFTER A POWER FAILURE GREEN TIMER LIGHT WILL NOT STOP BLINKING. HAVE TRIED TO RESET TIMER, UNPLUGGED POWER SOURCE. THIS IS A MITSUBISHI DLP WD52525
The Capacitors on the DM board need replaceing. The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the capacitors and the CD with instructions.
Dec 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Why doe my wd52525 dont turn on and all it dose is a green blinking star light
The DM capacitors have failed. You can get the V26 DM repair kit at www.tvrepairworld.com which should repair that issue the kit contains the capacitors and the CD with detailed repair instructions
Nov 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD52525. Green timer light blinking, tv won't come on. Read all directions for troubleshooting in owner's manual. Have pressed reset button, timer light never stops blinking. Unplugged...
You are not going to like this one little bit. The reason the LED won't stop blinking is because the digital module is not booting up. I have been fighting this model Mitsubishi for over five years now and the only solid fix is to send the entire chassis back to Mitsubishi for rebuilding. Pulling the chassis is a major job and with shipping costs and Mitsubishi's charges this repair usually runs around $750 to $850. However many owners that contacted Mitsubishi about this problem have gotten that portion of the repair bill coverd. That still leaves $300 to $400 for the tv shop that pulls the chassis and reinstalls it once it is rebuilt.
Jun 14, 2009 | Mitsubishi WD-62827 62" Television
Bad capacitors
go to the link below, they have the factory manual with fetailed photos of the disassembly and reassembly of your unit.
http://servicemanuals.vstore.ca/
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
212 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
