Question about HP DeskJet 950c InkJet Printer
Hp deskjet 950c
I MY PRINTER ONLY PRINTS IN THE MIDDLE OF THE PAGE AND IT WONT LOAD THE PAPER YOU HAVE TO MANUAL PRESS THE RED BUTTON TO GET IT TO PRINT
  • 1959elaine Jul 20, 2008
    my printer has no paper jam have checked that it prints normal but only up to the middle of page the cartridge does not go all the way across and the resume light keeps flashing all the time even though there is paper in
  • HP Master
  • 6,487 Answers
You can try cleaning first the cartridges of your printer using the printer utility installed on your computer and if you want you can also remove the cartridges and clean the inside part of your printer..
Good luck..............
Posted on Jul 20, 2008
  • 2,071 Answers
Click below for solution;
Documentation
Documentation
Posted on Jul 16, 2008
  • HP Master
  • 19,396 Answers
It is a problem with the mechanic.
  • Ginko
    Ginko Jul 16, 2008
    It looks like there are several problems with your printer mechanics.
    The printer does not pick the paper automatically because of a problem with the traction wheels or paper sensor.
    If it prints only on the central part of the page this is because either the page sheet is folded, or the print head is faulty, or the print head rail is bent.
    If it does not print first half of the page, instead, check cartridges and print heads.
    To fix it it will require a thorough inspection, this involve taking the printer apart and reassembling after inspecting the mechanics.
Printing Margins settings incorrect with Windows 7
if the printer have disk use it and install printer driver
Dec 21, 2013 | HP DeskJet 950c InkJet Printer
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
MY HP DESKJET 2430 WONT STOP BLINKING AND PRINTING BLANK PAGES
Follow these steps :
Disconnect the USB cable from your computer.
Make sure that letter-size paper is loaded in the sheet feeder.
Press the On button while also pressing the Ink button.
This product prints an operation check page that includes a nozzle check pattern. get more information and help from here
Hope this helps you.
Sep 01, 2010 | HP Deskjet D2430 Printer InkJet
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
I have a HP VPavillion computer with Vista and an
Vista is tricky like that. do you have the cd that came with printer try to reinstall it. maybe go to HP site update the drivers.
Jun 10, 2009 | HP DeskJet 950c InkJet Printer
Print is too small.
r u printing from internet...? if yes then save the document before you print on your desktop or copy the document on word and then print.
Nov 28, 2008 | HP DeskJet 950c InkJet Printer
Hp deskjet 5550-prints a ''hp deskjet 5550 Series'' page
Hi all of you
your problem sound as you have hanged Button, try clean it and refit it.
thanks,
Hamedo
Nov 19, 2008 | HP DeskJet 5550 InkJet Printer
HP 950C - no red!
I use a clear silicone tube to carefully prime the carts by sucking a dab of ink out of the tiny print holes before installation. I am careful to have a tight seal at the holes to prevent getting too much ink and possibly getting it in my mouth.
Oct 27, 2008 | HP DeskJet 950c / ScanJet 5370C InkJet...
Deskjet 950c
Most likely your encoder has become fogged due to aerosol in the printer. You can carefully clean this following the instructions here. Be sure to heed the warnings, the encoder is fragile and can be easily damaged.
Once you have cleaned the encoder force an alignment calibration, either from the toolbox of alternately turn on the printer, then press and hold the power button, then quickly press the formfeed buttion three times, then release the power button. If the alignment fails you may need to lean the bottom of the alignment sensor, it is located in a small black package just on the lower right side of the carriage. Open the lid, allow the carriage to move to the center then clean the sensor from below with a damp q-tip.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 14, 2008 | HP DeskJet 950c InkJet Printer
HP DeskJet 950c InkJet Printer Logo
137 people viewed this question
Ben Johnson
