Question about Minka Aire F812-IO Lineage? Fan
Lights and wall switch will not work
We had the lineage installed to a new home by an electrician and he could not get the upper lights to work but everthing else worked, the wall switch will not work at all and this is what operates the fan. can you please let me know what you think the problem may be?
    Novelist:
  • 145 Answers
If the wall switch will not work at all, but the fan still works this tells me the power is not being sent to the switch and back to the fan. If it is a single switch and the power starts at the fan there should be a black and white wire on the switch. (pull switch out of the wall to check...turn power off first!!) If so they did a switch loop and the power wire should be connected to the white wire up in the fan box and the power (black) wire connected to your fan lights and fan motor. You will also see your power feed cable consisting of a black and white wire. Black is your power and white is your neutral. That white wire will be connected to the neutral wires of your fan lights and motor. (Note: your fan will have to disassembled and taken down to diagnose this). Good Luck!!
Posted on Apr 28, 2010
On 10/12/10 electrician installed an Intermatic Inc. ST01C Self-Adjusting Wall Switch Timer in our garage to control outside lights over garage door. The lights were programmed to come on at 6pm and go off...
I believe your timer must be exposed to cold.
The CR2 battery in ST01C will only last 30 days when exposed to cold temperatures.
I was reading a pdf chart few months ago about timer batteries, and the power drop-off becomes really steep after 30 days.
Most digital programmable timers are susceptible to cold if they have battery or internal rechargeable battery that supports timer functions or acts as program back-up.
For example, I e-mailed Honeywell about their Aube rechargeable-battery-type-timer, and they said anything below 32F and the display becomes slow, and timer loses accuracy.
Your ST01C wiring is correct. I test timers. They don't operate if wiring is wrong.
I solved same problem with my back porch timer using GE 15070 mechanical dial timer. Home Depot sells in-store for $18.
Link below gives you photo, manual, and wiring instruction so you don't need electrician.
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
Open page and notice the timer below the 15070 has a photo insert showing on-off pins located on timer dial.
You move pins with ink pen or fingernail file.
Of course this is not self-adjusting digital timer, so I just set it for times I want, and it's easy to change times. It will be perfect for 6pm to 11pm daily.
And then use ST01C on a indoor switch.
You can wire the ST01C yourself by simply looking how each wire is connected now, or you can add a comment to this thread later and I will answer:
http://waterheatertimer.org/ST01C-program.html#ST01C
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 11, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Should a twoway room fixture actually be a three way ?!?!
The leviton 5603 switch described in the header is a three way wall switch.
I think what you are asking about is what electricians refer to as a "three way switch"
This is basically one outlet or device connected to two wall switches. 1) switch, 2) outlet or light fixture, and 3) another wall switch, three components, thus a three way switch. Installing or converting a fixture or outlet from standard to three way is something i would recommend contracting out to a licensed electrician. Unless you are really comfortable with electrical work.
It is a possibility that your wall outlets are already set up to be a three way switch. A lot of houses have this feature especially at the top and bottom of a stairway, depending on when your house was built. If it is not already configured it could mean stringing new wire behind the drywall which most often means tearing some of the drywall out so that it can be stapled to the studs and meet required building codes.
If, before the changes were made, you were able to turn on the light from either of the wall switches then you will only need to connect the wiring correctly at each of the components.
If you google 3-way switch you will find a ton of great info and wiring diagrams that will help you see exactly what goes into making them work, since they can be wired more than one way. It could help you decide whether or not it is a job you want to tackle on your own or if you want to hire a contractor.
Let me know if I didn't explain something clearly.
Mar 01, 2010 | Leviton 5603-wh 3 Way Decora Switch
Home blt.62 I am installing ceiling fan. when installed,fan works
You need to contact an electrician and have them evaluate your home's wiring in its entirety. They should also inspect the other work you've done. The wiring in your house is NOT to be installed in the same manner as the wiring in a boat or RV. You don't use heat shrink in stead of UL-approved splices (most commonly wire nuts in a residential application) and black tape. This is exactly why so many places require that any work on an electrical system be performed by a licensed electrician.
It sounds like somewhere in your house, you have a short to ground and your ground rod isn't diverting this voltage to ground. If it were functioning correctly, it would most likely trip the breaker on the affected circuit. This is not something to take lightly. Your safety and that of your family is at stake here.
May 17, 2009 | Speed Ceiling Fan 3-speed Switch By...
Leviton wireless switch fails to work all the time
50 feet is the maximum range for the switch, per manufacturers spec. Range is diminished somewhat for walls, doors, etc.
IIRC, there is a plug in transceiver available from Leviton, however, if the price of the booster for the main panel is included in the $100 installation, then I'd say that's a fair price. You may try to keep fresh batteries in the switch.
Jan 15, 2009 | Leviton #601-6696-I Ivory Wireless 3WY...
Wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Oct 20, 2007 | Hampton Bay 24002 Ceiling Fan
Minka Aire F812-IO Lineage? Fan Logo
239 people viewed this question
Top Minka Dryers Experts
Fan Fair Of Boca
Fan Fair Of Boca
 Jack Jr
Jack Jr
Are you a Minka Dryer Expert? Answer questions, earn points and help others
