Question about Dell Dimension 8200 PC Desktop
My Dell Dimension 2400 does not recognize plug & play for my HP OfficeJet Pro L7650 all-in-one. If I add the all-in-one manually, the computer says it's offline. I've uninstalled & reinstalled the printer software, tried it in all the USB ports, checked power connections, etc. I also did an online live chat with HP & they determined it was a computer issue regarding the USB connection & to contact Dell Support...which is a misnomer, as it's the most user unfriendly website I've ever dealt with! Hope you can help.
My solution was very simple...I just threw my computer out the window! Seriously, the problem has not been resolved...it seems that several types of Dell computers (in my case, the Dimension) have a problem with HP all-in-ones with regard to the USB 2.0 having enough power to recognize the plug and play option when installing the HP product. Dell's only solution (that I could find) is to operate the HP product thru a USB hub...so I guess I'll try that first and, if it still doesn't work, I'll probably just upgrade to a newer non-Dell Dimension computer.
Posted on Jul 16, 2008
Can I scan on HP officejet pro L7650 all-in-one
Upgrade ur drivers. Select printer icon n then rt click go to trouble shooting
Feb 13, 2015 | HP Officejet Pro L7650 Printer
HP Solution Center can not locate printer on network
To correct that problem better uninstall and reinstall the HP solution center and after that it should locate your working printer on your network...
Sep 15, 2009 | HP Officejet Pro L7650 Printer
Same as mentioned My HP Officejet Pro L7650 will not turn on. I a
try connecting the printer directly to wall instead of surge protector and see if that resolve the issue
Aug 17, 2009 | HP Officejet Pro L7650 Printer
Hp officejet pro L7650 will not print yellow ink
verify if you have ink in yellow cartridge
perhabs you should change it
Jul 09, 2009 | HP Officejet Pro L7650 Printer
Computers not sensing scanner via LAN
Scanning over network usually requires software to connect. First go to the drivers page as below. Windows Vista | Windows XP, download the latest drivers (the Full Feature one) as well as the firmware update for the OfficeJet. Plus the "Update" files that's dated newer than the Drivers.
Upgrade the firmware (this will reset all custom settings in the OfficeJet like IP address) with a USB connection.
Run the full feature installer and if there is an option for Networked OfficeJet, then tick it. Also you may need to change/disable firewall for the installer to pick up the networked OfficeJet.
Scanning over the network usually connects with a customized TCP port. And most likely the Windows "Scanners and Cameras" will not pick up network scanners unless it's been defined manually (installer can do this part).
Jun 15, 2009 | HP Officejet Pro L7650 Printer
HP OFFICEJET PRO L7650 ALL-IN ONE TO DELL XP 2000 CANT GET TO INSTALL PROPERLY
hello jackjudy
are you trying to install with a cd ?
this could be a cd error, have you tried to download the software to pc form here select your o/s and download fresh drivers
Software & Driver downloads HP Officejet Pro L7650 Color All-in-One
riz.
Jul 07, 2008 | HP Computers & Internet
Scanning Instuctions
go in the my computer option in that place you find our the option hp scanjjet L7650 then double click on this option you will get scanning wizared the you con scan otherwise go to the destop and double click on hp scanning and imaging software then you can change the as you want that seting and you can scan easily
Jun 26, 2008 | HP Officejet Pro L7680 All-In-One Printer
USB Device Problem after installing new printer
did you get a fresh set of drivers when you got that new hp? try this link, and advise your success on this.
Mar 09, 2008 | HP Officejet Pro L7650 Printer
Dell Dimension 8200 PC Desktop Logo
107 people viewed this question
Alun Cox
