Question about Dishwashers
Maytag dishwasher model# MDB9150AWW and serial# 27600460CL will not run. It lights up and sounds like it tries to start every five seconds, but never does. I pulled it out and the motor on the bottom is hot. No obvious signs of external damage, but there were mice living back there.
  • 1894 Answers
SOURCE: My Frigidaire Dishwasher motor is not spinning rinse cycle
am not sure.. just try this
Check with a multi-meter for 115/220V on motor's tags.
If you don't get this voltage measurement, your problem is not with the motor.
In case you have 115/220V on motor's tags, try first to replace its brushes (2 carbon contacts that transfer the curent to the motor's armature).
try this good luck
Posted on Dec 25, 2007
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
localwonder
  • 6784 Answers
SOURCE: Maytag Dishwasher Leak
HI. this is a inlet assembly issue. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
***(((NOTE-- It i possible that the valve housing has cracked as well. make sure that the hoses are connected properly during your testing. If there are no hose issues, this will be a defective valve assembly)))
Posted on Sep 12, 2009
SOURCE: asko dishwasher model 1475
Believe it or not that unit has a pressure switch like a washer attached to fill and pump out that is more like to be the problem.
Posted on Feb 16, 2010
Macmarkus
  • 2605 Answers
SOURCE: My Bosch dishwasher runs long.
Welcome to FixYa.
Based on your description
I'd say the issue actually with the control...unfortunately.
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the model & serial number, you can check with yours, though many not included here still suffers from the same problem...you'll need the serial number too. Here`s the link if you want to see for yourself **
http://microsites.boschappliances.com/safetyrecall/dishwasher/
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...or takes a long time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning and obviously no "extra" heat ( aside from the water inlet temp. ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Jan 03, 2011
The control panel is flashing a L. What does this mean?
Hi.
The model indicated: MDB5651A does not have display and the error codes are shown like flashing lights. If that is your model and problem please just tell me what lights are flashing.
In Maytag with display instead, the L on display means that the machine is control locked. That is not an error message, but a code telling that the machine has been locked by the user (probably by mistake since you are the user).
I quote from Maytag technical documentation:
? If a cycle or option pad is pressed after the controls have been locked, the indicator light next to lock graphic will flash five times. On selected models with a countdown display, the display will flash the symbol "L" simultaneously with lock indicator.
? This option does not lock the door, only the dishwasher controls.
To set :
1. Press the Heated Dry pad for three seconds.
2. An indicator light next to the lock graphic will illuminate when the controls are locked.
To Cancel Control Lock:
2. The indicator light will go off as instructed.
Try pressing the the Heated Dry pad for three seconds. If that doesn't work disconnect power. Connect back and try again unlock (power off does not remove the lock). If that still does not work there may be a faulty part. In that case turn appliance off and give me the full model number.
Start holding down the Heated Dry pad for three seconds. In normal conditions that is enough to get rid of the L and of control lock.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Maytag 24 in. MDBH950AWS Built-in...
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Washer fills, runs 5 seconds and stops for 5
Major problems here. Sounds like a circuit board thing. If the machine is on the old side , ditch it and start new.
Oct 06, 2009 | Maytag Dishwashers
Maytag MDB-3 won't start, display flashes
Hold down the lighted "3" for five seconds to unlock the child safety lock
Feb 15, 2009 | Maytag 24 in. MDBH970AWS Built-in...
Dishwasher won't fill
The only three things left are:
Is the flow to the fill valve adequate...kinked line...for instance.  Drain valve is partly jammed...letting water out early or timer is bad..I'd go with the valve.  You may be able to clean it out.
Dec 12, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag dishwasher blinking
try holding the lock button from three to five seconds if that doesn't get it try removing power for same time and advise
Jan 10, 2008 | Dishwashers
MAYTAG DISHWASHER STUCK WITH LIGHT BLINKING
Try holding down "Heated Dry" for about five seconds, until the light switches off. You should be good to go.
Oct 20, 2007 | Kenmore 15129 Built-in Dishwasher
Maytag dishwasher MDB5600awb
i need your serial num its important 17
Sep 07, 2007 | Maytag 24 in. MDB5600A Jetclean II...
"3 second" light flashing
Pard, does your serial number end with either WS or WU? If so, Maytag had a issue with the main board, triac shorting and possibley damaging the motor windings. If your serial numbers fall under this, you are probably covered under the service flash. Im not really sure what you mean by the 3 second button flashing. Check the numbers first and post back. Catriver.
Apr 21, 2007 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
279 people viewed this question
Top Dishwashers Experts
