Question about Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder
DVR S4040R Tivo box
It was malfunctioning on just Fox 360 and 29 so I called Direct TV and they told me to unplug it for a couple minutes and replug it in the same strip I had it in for the last 5 yrs. I also tried directly into a wall outlet. Nada !! I also tried unplugging for just 15 seconds and also for several hours. Also left it plugged in for the night and the fan continued to run, but no led's, picture or sound.
  • 4,472 Answers
Your best bet would definitely be to upgrade recievers. You can call directv and see if they will give you a deal, or check ebay or call your local directv electronics dealer.
Hope this helps.
Thanks,
Lee
Posted on Jul 19, 2008
  • 3 Answers
Your hard drive may have crashed. Can you hear any disk activity when you plug in the unit? The hard drive can be replaced, but probably better to either just get a replacement unit (you can get them on eBay for $40 or less) or upgrade to a newer receiver.
Posted on Jul 18, 2008
Will a dvr/tivo built for direct tv convercablet to a cable tv service with a cable card from suddenlink its a sd80 tivo dvr mfg 2004
Unfortunately, DIRECTV TiVo DVRs will work ONLY with DIRECTV. They cannot be modified to work with cable.
However, there are many TiVo boxes that do work with cable and they are as low as $99. See, for example:
http://www.weaknees.com/4
http://www.weaknees.com/5
Oct 28, 2013 | Televison & Video
I have an LG 42LG70 42 in. HDTV LCD TV. Whenever I have my brightness setting below 40, my Dish DVR will no longer respond to its Dish issued remote control. If I turn the brightness anywhere above 40,...
Tries unplug,replug the DVR box an hour later.The box should reset itself and update it software.The box should work normal again.Not,call Dish Network to replaced the box,have intermittent problems.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
Vizio 32 inch hdtv, Motorola DVR box...Whenever I turn the tv off, the cable connection is lost and I have to unplug/replug the DVR box when I want to watch the cable again. It's not the box, because I...
Here a way,u could test,if it the cable signal,tv Main tuner board have problem or the DVR box again.U have analog antena?Or go and a buy a digital antena.Reset ur tv to free air signal and use it for few hours,turn it off/on and see if u losing signal,require unplug,replug to get signal back.Two problems solved ur tv board or cable signal good or not?Than U know it the DVR box and have connecting problems.
Mar 19, 2010 | Vizio VW32L 32 in. LCD HDTV
I need trhe codes for direct tv for my jumbo remote its a dvr box
Here are the Innovage Jumbo Remote codes for Direct TV satellite boxes:
200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217.
If none of these control all of your DVR functions, try adding these DVR codes from other manufacturers:
146, 147, 148, 184
These codes work for Tivo, Replay TV and dvr models made by Panasonic, Philips, RCA, and Sony.
Hope that helps.
Oct 03, 2009 | Innovage Jumbo Remote Control
SIR-S4040R will no longer power up (except the fan)
hold in the power button for at least 10 seconds. It should reboot. If not the DVR needs to be replaced.
Nov 12, 2008 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Audio Problem on a Pionneer DVR-810H Recorder
Thinking the problem might be the cable box..I bypassed the Tivo and hooked the cable box direct...there was audio on ch. 3 ....reconnected the Tivo and the audio was fine...strange?
Thank you.
Ken Havel
Greenville,WI
Oct 10, 2008 | Pioneer DVR-810H DVD Recorder
TIVO HD DVR
OK, I had Dish network come out and install DVR HD. Had pixel des torsion viewing everything I recorded. They came out 3 time and replace DVR and check everything 3 time with no improvement. I had them remove everything.
I called Direct tv and they did the same thing. installed there dish and cables and DVR. Same problems. My question is? Is this the nature of this equipment or is there something they are missing.
Jul 11, 2008 | Tivo Series2 TCD649080 Video Recorder
Direct TV DVR Recording Problem
call tech support & ask them to hit your box to reset it, in the meanwhile unplug it for 15 seconds
Apr 22, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Loss of channels
If you mean "losing" as in you could no longer tune to those channels because they disappeared out of the channel list entirely, then it's likely a software problem.  If you haven't already, try resetting your DVR to factory settings (since this unit is TiVo powered, it should be under the main menu, Messages and Settings, then Restart or Reset system; follow the on-screen instructions to reset the system).
If you mean "losing" as in you can tune to the channel but there's no signal, then that sounds like a tuner problem to me.  If the box is still under warranty or you lease it, have it repaired or replaced.  If you bought the box and the warranty is up, it looks like you might have to get a new one, or pay for the repair out of pocket.
You might also try calling back to DirecTV tech support and asking to be escalated or to speak with a supervisor; especially if it's a box you're leasing from them, since it is definitely *their* problem in that case.
Oct 21, 2007 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Tivo Dtv
No, you need a regular directv receiver, or a directv w/ tivo receiver or a directv dvr.
Oct 03, 2007 | Tivo Humax® HUM-T2500Digital Video...
Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder Logo
110 people viewed this question
Jerry Greenberg
Jerry Greenberg
