Question about Cameras
I put my memory card in the memory card port on my computer and now my camera is telling me there is a card error, i have done everything i can think of and there are some extremely valuable photos on the card.
    Problem Solver:
  • 10 Answers
Maybe i dose not support a high mem card
Posted on Jul 15, 2008
Concord eye q 4363z says card error when put in sd card and says formatting will erase all data
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Dec 18, 2012 | Concord Camera Eye-Q 4363z Digital Camera
All of a sudden my xd cards are coming up with errors. I have never had a problem like this. It's telling me to format the card, but if I do that I will lose my pictures. Is there something wrong with...
You need to download your pictures from the memory card to your computer, once on the computer hard drive in a folder then format the memory card. Yes you will loose the pictures on the memory card BUT you will start over with a brand new clean surface on the memory card to put more pictures on. I think it's pretty amazing that the camera is actually telling you what it needs you to do. Most would just give you an error code without instructions.
Feb 15, 2011 | Cameras
My fine pics camera is not uploading the pictures to my pc. It's saying connect camera and turn power on. Can you please tell me what the problem is
I think you are missing a step or pushing the wrong power button.
The sequence should go like this first make sure the batteries are up to power if there is an interruption the pictures could become lost and corrupt the memory card.
Turn the camera off, connect the USB cable to the computer USB port not a hub or keyboard port.
to turn the camera on Fine Pix Viewer will start and the save Image Wizard will display follow on screen instructions to download pictures.
To disconnect make sure the indicator lamp is off then press the same button for about a second to shut the camera off THEN disconnect the camera from the computer.
You should then format the memory card to begin fresh with a clean card and allow the camera and memory card to properly communicate between each other without errors.
Here is a diagram to show you were and how to format the card.
Have fun with your camera
Jan 17, 2011 | Fuji Finepix Z20fd Digital Camera
Last friday i took some pictures and transfered them to my pc as i have done for the last 18 months. Over the weekend i took some more pictures. I went through exactly the same routine in connecting he...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Nov 25, 2010 | FUJIFILM Finepix S1500fd Digital Camera
After inserting the new SanDisk, SDHC Card, 8GB the camera prompts "Memory card requires formatting", press continue; warms that formatting will delete everything on memory card; pres continue;...
First thing; check owner's manual and USA distributor, make absolutely sure that this camera is able to read/write to a 8GB card!
If so, put that card into your computer, directly into appropriate slot or through a "reader" and the USB port. If computer runs Windows, access My Computer, click on external memory device, and RIGHT CLICK. You will get a box which offers to format the card. You can rename the card at the same time. The computer's format routine is stronger that the one in the camera. If problem still happens, consult distributor. May be fixable with a cable from camera to USB port, you download new software from distributor. Follow their instructions EXACTLY.
May 14, 2010 | Kodak EasyShare Z650 Digital Camera
My fujifilm finepix s1500 tells me there's a read error when i want to look at photos i have taken, they don't show up when i put my sd card in the computer either, how can i fix this?
i have the exact same problem it works again when you erase the memory card i think its nont the actual memory card but a general camera problem ive tried both my sd 8 gb card and sdhc 16 gb card and both have the same problem
Feb 02, 2010 | Fuji FinePix S1000FD Digital Camera
After slideshow memory stick is missing photos (not on computer)
If you put the memory stick back into the camera can you see them thru the camera menu? If so your computer's SD card port may be having issues. try using the card in another computer or use the cameras USB cable to transfer the pictures from the camera to the computer if it has one. Do other memory sticks work in the computer ok? If you cannot see them in the camera either then the pictures will be corrupted and probably cannot be recovered. Then the card will need to be formatted to erase any errors on the card. Always use the camera to format a card whenever possible...Hope that helps.
Sep 19, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Memory card error
put the card in your computer, right click on the disk and do a quick format.  Then remove and try in your camera again.
Mar 18, 2009 | Pentax Optio S40 Digital Camera
Cant download pictures usb
Take your sd memory card out of your camera, and put it in your computer. A file with your pictures should appear. Copy thoes pictures into a different fold on you computer. Take you sd memory card out of your computer and plug it back into your camera. Your pictures will be both on your camera and on your computer.
I hope this solution helps. Please rate this solution.
Oct 10, 2008 | Nikon COOLPIX L18 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
