Turn the big yellow top, if it's air tight use a plier and gently turn it. That will the trick.
WARNING!!! Becareful not to over fill the water reservoir by doing so the water boils making it leak. It is extremely dangerously as I steam burned my hand. Other than that u won't have a problem.
In order, to add water to your steam iron without getting messy, just tilt the steam iron slightly and find the right tilt where the water goes in. Actually, this tilt is needed so that the air inside the water tank can escape. Once you tilt, and give the air a passage to escape, the water should flow in really quick
My iron will not open.
The iron has a small yellow 2 partb button behind the large yellow tank fill knob. Why does it have a "tab" or switch within the button? What does it do besides spray steam?
What does the small yellow button with the slot do on the handle?
