Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Can't get the bottom off!
I have the same problem - the belt is broken but I can't get the bottom off. Help. Please and thank you.
    Welcome Back:
    Visited the website for 2 consecutive days.
Where the light is there is a piece that protects the light. Than carefully push both sides in and lift that top piece off. there will be two visible screws (flathead will be fine). un-screw and then pri open.
Posted on Jan 04, 2009
Brush wont spin
Hi carolinearch...
Sounds like you have a broken belt...remove the bottom of your vacuum and replace the broken belt and you should be good to go.
Please take time to rate me thumbs up
Sep 14, 2011 | Hoover S3765-040 WindTunnel Bagless...
I have a 20 yr old upright U4689-910 with a broken agitator belt. I have a replacement belt. I have removed the L shaped plate on the bottom of the vac. It is not clear to me how to replace the belt at...
If it is like the older hoover models you need toDISCONNECT FROM MAINS FIRST then
lift out the roller with the brushes on it, grip firmly at both ends and pull away from body of hoover, loop the belt over it and push it back in. Make sure you loop belt over the pulley the correct way or the brushes will rotate in the wrong direction! (there should be a diagram to show that on the hoover)
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Mar 05, 2011 | Hoover Vacuums
Brush on underside not working, please help.
Turn the unit over and remove the four screws that retain the bottom plate over the agitator. Remove the bottom plate and see if the belt of off or broken. The belt part number is printed on the data label for the cleaner.
Oct 02, 2009 | Hoover U5753-900 WindTunnel Bagless...
The main brush will not spin
I would guess the belt is broken. That happens often. Get a correct belt. Remove the brush roller. Wrap the belt around the roller and drive peg. Reasemble -- easier said than done, but keep trying.
Sep 27, 2009 | Dyson DC15 All Floors - The Ball Bagless...
I have a dyson Absolute 04 hoover, the brushes underneath do not turn,I can see the belt but am not able to get into to it to change it.could you please assist. thank you.
HELLO, YOU HAVE 4 SCREWS THAT YOU TAKE OFF THE BOTTOM COVER TO REMOVE OR HELP GET TO THE BELT, IF THE BELT IS'NT BROKE TRY SPINNING THE BRUSHES BY HAND TO SEE IF YOUR CAN SPIN IT OR BREK IT LOOSE IF IT IS THE BELT THEN YAA REMOVE THE BOTTOM COVER TO HELP REPLACE THE BELT.
Mar 29, 2009 | Vacuums
My vacumn wont pick up from the bottom but the hose works fine. I emptied the bag and the green light is on.
Either the glide plate at the bottom is blocked or the belt is broken
Please leave feedback
Thanks
Rob
Feb 12, 2009 | Bissell 3522 PowerForce Bagged Upright...
My vacumn wont pick up from the bottom but the hose works fine, I have an empty bag and the green light is on.
Thanks
Rob
I have a Dirt Devil Swivel Glide Vac with a broken belt. I have purchased the correct belt(#4).The bottom is off and I cannot tell where the belt connects to. Please help. Jann
it connects to the left side with the little metal rod sticking out.then connect to the wooden roller. in the space without the brush on it. roll the wooden piece to check if everything moves. then put back together.
Aug 27, 2008 | Dirt Devil Vacuums
I have a Hoover Vacuum Cleaner, Runabout Supreme, on which the belt has broken. I purchased a new belt, part number 38528-040. I need some instructions on how to install the replacement belt? Thank...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=728341
Generic problem for all Vacuums
Posted by Jimbob48 on Jul 01, 2008
I need some instructions on how to install the replacement belt? Thank you. JBS
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are screws, clips or levers on the bottom of the vacuum and you need to either remove the bottom plate and once you have taken the screws, etc. out the top cover will come off. And then you can proceed with the removal and the install of the new belt. 1st you need to remove @ least one end of the Hoover brushroll and take of the old belt and slide on a new belt. Once the belt is on the pulley side of the brushroll; then re-install the brushroll. Make sure that the brush is spinning freely B4 you install the new belt, then take a belt puller or a screwdriver with a left or right hand hook to use as a belt puller and then stretch the belt onto the motor pulley, then take and roll the belt until it is tracking straight and then re-install the top cover and or the bottom plate, tighten down the screws, levers or clips. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover Elite U5061-900 Bagged Upright...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
44 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
