Question about Cameras
I have a sony CCD-FX430 Video camera recorder/8m The tape will not rewind. what can I do. Do the heads need cleaning or what?
  • cherokee7 Jul 15, 2008
    Yes, I did check with another tape and it still
    does not rewind.
  • cherokee7 Jul 16, 2008
    Now tell me how to change the motor belt.
    Just open the camera is not enought. please
    give step by step instructions, since the
    book I have does not give this information.
    Genius:
  • 2,035 Answers
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://www.nodevice.com/manual/sonymans/manual167pdf/get1718.html
Good luck....
Posted on Jul 16, 2008
    Master:
  • 726 Answers
Its sorta hard to change the little black belt for the motor u have to open the hole cam if u just open the tape bit u can see the belt but hard to get to its quite cheap to be replaced and it has nothing to do with the heads need cleaning
  • 2,794 Answers
It's probably easier to take into a shop and see if the belt can be fixed or if the motor is working properly in the player.
  • 2,071 Answers
Mechanism stocked due to dirt and dust need to clean and a little push to the tape head maybe it's jamming:
  • The capstan shaft: This is the motorized shaft that pulls the video tape through the tape path.
  • Pinch roller: This is the wheel that presses against the capstan shaft, so the capstan shaft can pull the video tape through the tape path.
  • A/C head: A mechanical part that contains the record and playback audio head, the audio erase head.
  • Tension rollers: These rollers attenuate vibration or flutter from the video tape as it is moving across the record/playback head.
  • Erase head: As the name implies, this head erases all recorded information off the video tape before it reaches the recording head.
  • Roller guides: These guides pull the video tape onto the tape path and align the video tape to the video drum (the part that holds the video heads).
  • Video heads: The most important, expensive, and dirt-sensitive piece, the video heads (video drum) pick up the image part of the signal off the video tape, or record the video image onto the tape.
Posted on Jul 15, 2008
  • 2,326 Answers
Do the other funtions work properly on your camera such as play and fast forward?
    Sergeant:
    Champion:
  • 297 Answers
Open your camera and change the motor belt...
    Sergeant:
    Champion:
  • 310 Answers
Did u check with another tape...............
  • khader ibrahim Jul 15, 2008
    problem in ur tape only try another tape...............
When playback of tape, fuzzy, not clear picture, or blue screen with sounds
try rewinding the tape and play it from the beginning.if still the same,video heads may be dirty and needs to be clean.i recommend you use a dry head cleaning tape.after which reinsert tape and play it again.if issue persists use a diff tape with previous recordings.if still no go,use new tape and try recording on it,play it back and check.if still the same your unit will require service.thanks:) hope this help.
Mar 12, 2010 | Sony Handycam CCD-TRV308 Camcorder
Won't playback. acts like it's locked up.
This may be corrected by fast-forwarding the tape for a few seconds and then rewinding it back to the point where the issue first started. However, if the issue continues, this could be a sign that the video heads are dirty and need to be cleaned. Use a Sony MiniDV head-cleaning cassette (DVM-12CLD) to clean the video heads.
If the movie continues to stop at the same point even after cleaning the video heads, this could be an indication that there is a problem with the recording on the cassette tape. If this is the case, the data on that portion of the tape cannot be recovered.
NOTES:
  • It is recommended that a high-quality Sony MiniDV tape be used for recording.
Aug 07, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Won't playback and menu won't respond. Acts like its locked up.
We can see the image in fast forward or rewind but and no audio
Many parts are still available on these camcorders however if it needs a video head for example, and it's not avaiable it may be a better idea to get another 8mm camcorder off ebay, or maybe a pawn shop. just test them with a new blank tape first before putting your family tapes in.
Jul 21, 2009 | Sony Handycam CCD-TRV308 Camcorder
Sony 8mm camcorder will record sound but no video
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Mar 28, 2009 | Sony Handycam CCD-TR517 Camcorder
Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Nov 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
I have an old Sony Hi8 Handycam model CCD-TR705E. Have not used it for about 4 years and decided to upload tapes to DVD via a DVD recorder. Worked fine for the first 5 hours of film then suddenly picture...
Try to use video head cleaning cassette one more time and check. Problem still exist then....
There is a very special cassette used to clean much dirty video heads calls Lapping Tape.
This is provided only to Sony Service Centers.
You need to contact nearest Sony Service Center.
Oct 06, 2008 | Cameras
Camcorder wont playback recording
Dear Lauren,
You didnt write camera model and make. any how, you need Head Cleaning Cassette for your camera to clean its video heads. Video heads are dirty/ clogged so camera doesnt show picture in playback. Please dont touch video heads physicaly because it may broken easily. always use video head cleaning cassette.
Apr 20, 2008 | Sony Handycam DCR-TRV250E Digital...
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Cameras Logo
109 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
