SOURCE: Printing mostly blue with lines across page
I have the same problem that you are haveing, I changed the ink ,both black and color, and it hasen't helped any, I wanted to get a new copy and printer machine but I don't want to get one and have the same problem. I have runined a lot of print paper trying something else new. I am open to all suggestons. thanks Ken.
SOURCE: the pgbk on the Nozzle Check Pattern doesn't print
It means you either need a new printhead, QY6-0061-000, or the purge assembly is worn out and not cleaning or priming the black properly. You can change the printhead but the purge assembly is a shop repair.
Testimonial: "thanks! I was leaning that way from what I had read online!"
SOURCE: printer head alignment failed
That is the only thing that can be donw by the end user through software,
For more fine tunning, please get it to a nearest service center.
SOURCE: Lexmark Z615 inkjet printer - whetther I print in
The problem with your printer is the print head. Usually you have to run the clean nozzle thing 5 or 6 times to clean the print head nozzles and if there's still no improvement after that then print head needs to be changed for the printer to work properly. The bad news is that a print head costs almost as much as a new printer.
