Question about E-Machines eMachines Desktop PC
Wireless adapater not showing up in device manager
I have a Emachine and used to be able to surf the web with the wireless adapter, now I can no longer connect and it just seems like the adapter disappeared. It is no longer showing up in the device manager. Could someone help me. I would like to be able to get back online.
If you feel comfortable opening your tower up and checking if the adapter card is still seated into the pci slot, that is the first thing I would do. Turn the computer off. Unplug it from the socket. Open the case and find the card - it's easy to find with the antenna sticking out of the back. Just use enough pressure to be sure it is down all the way. Put things back together and turn it back on. If it is recognized you'll be prompted for a driver cd (or Windows will install its own driver) and you'll be off and surfing. If it doesn't recognize it, the adpater card is aparently defective and needs to be replaced. (It wouldn't hurt to check the adapter's support site on the web - assuming you have an alternative way for connecting to the web.)
Posted on Jul 16, 2008
Need Download Software
You could go online and download it from the manufacturers web site.
Mar 07, 2014 | Adapters.com Bluetooth USB Adapater, USB...
Tip
Acer Aspire One Netbook Slow Wifi
Acer Aspire One Slow Wifi <span style="font-weight: bold;">Using my Aspire One I noticed that, in spite of an optimum signal level, the surfing and page opening was slower than on my other computer. Looking through the web I found many other people were experiencing this problem so i have a suggestion for a solution that is working for me......</span><br style="font-weight: bold;" /><br style="font-weight: bold;" /><span style="font-weight: bold;">It seems like a problem with the power management on the wireless adapter.</span><br style="font-weight: bold;" /><span style="font-weight: bold;">To solve it go to the Start &gt; Settings &gt; Control Panel &gt; System &gt; Hardware &gt; Device Manager. Then you have to expand the Network Adapters option and right click the wireless adapter "Atheros...Wireless Network Adapter"& select Properties then go to the Advanced tab. Now select the Power Save </span><span style="font-weight: bold;"></span><span style="font-weight: bold;">Mode</span><span style="font-weight: bold;">in in the left colum </span><span style="font-weight: bold;">and set it on the right to Off Value, then press OK and close the device manager.</span>
on Nov 22, 2010 | Acer Aspire One Netbook
Cannot detect wireless
Make sure you have the wireless switch turned on that is located somewhere on your laptop (usually on one of the sides or at the front under the palmrest area). Also there is a FN (Function Key) + (F1 thru F8) key sequence that will toggle the wireless from off to on. Hold down the FN key then find the corresponding function key that toggles the wireless. Normally the wireless key will be denoted with )))) on it. If all fails, go into the device manager and check to see if the wireless adapater and driver are both ok. Click Start/Control Panel/System and look for device manager. Under Device Manager look for Network Adapters. If it has a + on it, click the + to expand the Network Adapters. Look for the wireless adapter and right click on it then click properties to see if it is working properly or click Update Driver to reinstall the driver.
Mar 15, 2012 | MSI M670 Notebook
I have an emachine d620 ive just had to re format it but how do i get wireless bk
just go to device manager from my computer properties and check the network adapters select the wireless adapters and check which company adapters are installed if u r havng drivers then install else connect ur system with lan and select the wireless adapter and go for update drivers from internet .Let me know any other problem u recive
May 23, 2011 | Computers & Internet
I have an msi laptop and the wireless capability is turned off. I've read most solutions on the internet and nothing is working. There is no switch on my laptop and no fn button combinations work. help!
Check the "Device Manager". Right click on "My Computer" or "Computer", click properties. The System Properties window will come up, go to "Hardware" then click the "Device Manager" button. Check "Network Adapater " if the wireless network adapter is enabled. A red "X" usually appears at the top of the network adapter if it is disabled, if so right click then "Enable"
Hope this help. Goodluck!
Mar 28, 2011 | Computers & Internet
I had put my desktop in storage for a year. Before storage it worked fine, with the wireless adapter. When I start up the computer, everything works fine. When I plug in the wireless adapter via a usb...
try different usb ports.
trying something else with a usb connection, if it restarts will all of the above then its a dodgy usb connection which has weaken during the hibernation period. and will need looking by a techy.
if the above dont do anything then it could be the adapter
Oct 15, 2010 | Linksys Wireless-G WUSB54G 802.11g/b
Im trying to get online with my laptop wirelessly and it wont work what's wrong?
Might be possible that your laptop don't have a wireless adapter in it. First please check in device manager whether you a wireless adapater in it or not.
FOR WINDOW"S
my Computer>(right click) properties>Hardware>device manager.
In case you have turn it on by getting in to services.msc you'll have wireless zero configuration right click on it click on enable.
If not then purchase it and then use it
Hope this will resolve your issue.
Nov 02, 2009 | Linksys Wireless-G Broadband Router
6T04 Adapter failure
That 6to4 adapter has been a problem for as long as I have been aware of it but I only have that issue when I use my print server. I don't believe the 6to4 is your actual wireless. Are you using a wireless print server?
Sep 04, 2009 | Packard Bell 1580509280 Network Adapter
Wireless hotkey not working
i belive that when your computer boots you press F2 and the wireless card is automatically turned on
Mar 21, 2008 | Fujitsu (S26391-F2494-L100) Bluetooth...
E-Machines eMachines Desktop PC Logo
108 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
