Question about Sony KP-61S70 61" Rear Projection Television
Sony kp-61s70 I was just recently given a 61" projection tv and it has a pink hue to it. i have tried to adjust every picture setting available. Is this worth fixing? Thanks,
I used to work at an arcade and we constantly had the problem of hues on the screen, there is a product you can buy that will fix this problem, though I'm not sure how much it costs since we just had one at the arcade. It is a magnatized wand that you plug in to a power source and wave around in front of the screen for a few moments. It did the job everytime.
Posted on Jul 18, 2008
Picture scrambled / multiple pictures
CONVERGENCE PROBLEM. FIND A HONEST TV TECH. MAYBE A $300 REPAIR
Nov 11, 2013 | Sony KP-61S70 61" Rear Projection...
Sony kp-57wv700 cannot adjust color or hue
if you have a big sub right against it it needs to be moved away as the magnets can affect the big screen picture.
Mar 30, 2012 | Sony KP-57WS500 57" Rear Projection...
Very Dim Picture on Sony KP-61s70
Have you had the projectors dusted? They'll acculate a lot over the years and you'll notice some dimming as time goes by.
Sep 21, 2009 | Sony KP-61S70 61" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony kp-61s70 hour glass shape on picture bows in
the sony service menu can be entered by pressing "display" "5" "vol+" also the diagnostic screen can be reached by vol- instead of + when you are in the service menu the number buttons navigate it its a little tricky at first but as long as you dont hit enter before you exit if you mess up it wont save just make sure if you fix it you save it by pressing enter
Jul 13, 2009 | Sony KP-61S70 61" Rear Projection...
Need blue tube for sony 61" kp-61s70
Heres a link to where you should be able to get a used Tube for your model you can leave them a email with your model number and what youre needing and they respond quickly.
http://servicemanuals.vstore.ca/
Jun 14, 2009 | Sony KP-61S70 61" Rear Projection...
Sony KP-53V45 color issues
When ever a tube starts to short or is shorted set always will have over bearing drive lines then shut down like RED if it was bad, set would come on long enough for red lines across set then shut down this is the same with all 3 tubes.Also if you think it might be green tube disconnected green CRT board on neck of green tube if set comes on and plays then it is green tube do all 3 tube this way one at a time this will tell you if you have other problems.
Dec 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony Rear Projection TV - Red tube too strong
remove the front speaker assembly and the small access panel behind it and you will see a small square control assembly with 6 dials on it 3 control the color guns and 3 control the 3 gun focus. Try turning down the red control slightly they will be set up just like the CRTs red green and blue.
May 16, 2008 | Sony KP-57WS500 57" Rear Projection...
Pink in picture and green ghosting on live program with live people in picture
yes sounds like all 3 tubes are going bad. they are prolly not available anymore. try to adjust the settings in the menu. adjust PICTURE as low as possible and boost the BRIGHTNESS this might help but fixing this tv would not be cost effective.
Oct 17, 2007 | Sony KP-48S75 48" Rear Projection...
Sony KP-61XBR48 Service Menu Item Keeps Changing
the only thing to do is pick which video mode you want (tv, vid1,2,3,etc) and then turn off and then immediately on for an hour or two and then the picture will come on. I,ve heard it's an internal transformer problem.
Sep 26, 2007 | Sony KP-61XBR48 61" Rear Projection...
Sony KP-61S70 61" Rear Projection Television Logo
226 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
