Question about Xerox Phaser 8200 Laser Printer
Xerox phaser 8200
Hey can you send me those instructions on how to change the bulbs in a drum heater my email is: thank you
  • claban Aug 12, 2008
    I have an error code 15,004.45:22805 on my Xerox 8200. I think it is the same problem
  • puterdoc Jan 16, 2009
    can i get instructions too.
Can you post our solution for all to see?
This is the whole point of an open discussion forum.
Posted on Sep 05, 2008
  • 2,072 Answers
Sent the directions to your E-mail.
Just take your time, its more patience than difficult to do.
You do need torx drivers to do the repair.
Posted on Jul 15, 2008
Xerox phaser 8200 fault code 15.004.45:30386
That is a drum heater fault code. The drum heaters are 2 ,,, 150 watt halogen lamps. One or both have burnt out.
You can verify this by shutting the machine off, then turning it back on and look into the fan opening at the right side of the machine. See if you see a glow inside the machine. I doubt you will. if not you will need to replace the lamps. Let me know if you want me to send you info how to change them.
Mar 09, 2010 | Xerox Phaser 8200 Laser Printer
Phaser 8200 error code
I think I had this error once. Could be your bulbs (one or both) are out or are on their way out. I had to replace mine. They are 150 watt halogen bulbs. When you open it up, do you see lights on the side peering in?
Jul 02, 2009 | Xerox Phaser 8200 Laser Printer
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Error 15 004 45 37888
From the service manual:
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
Mar 13, 2009 | Xerox Phaser 8200 Laser Printer
Xerox 8200
You can not change the bulbs in the paper pre heater you have to get the whole paper pre heater unit.
Dec 15, 2008 | Xerox Phaser 8500/DN Printer
Where in Belgium Europe can I find Heating halogen ligths for a 8200 phaser printer.On the old continent we use 220 volts. Xerox asks 200? plus a heavy repair fee ... Thanks for help
If you are able to do the repair yourself, then remove a lamp from the preheater assembly and look at the voltage and wattage on the bulb itself...on some there is also a lamp part number.
you can also order a repair kit from e-bay. The same lamps are used in the Phasers 840, 850, 860 & 8200
Here are 2 links that have what you need (if the internal voltages for the printer are the same in europe as in usa):
Dec 14, 2008 | Xerox Phaser 8200 Laser Printer
Error phaser 8200
This error message is related to the drum heater malfunctioning. It is basically 4 small halogen bulbs that warm up the image drum. Sometimes one or two of the bulbs will blow causing this error. The part # is 650-4228-00 Drum/Paper Heater assy. It is not extremely difficult to change, however you need torx bit screwdrivers to remove the components, also there is a very delicate paper sensor that needs to be removed, so you may want to have a technician replace it.
Hope this helps!
May 20, 2008 | Xerox 8200/DP Thermal Printer
Tektronix Phaser 8200 DX what is error n°15.004.45:77685? Thanks
That is a failure of the drum heater.
The easy way to determine if they are working is this.
Shut the machine off, turn the lights off in the office, or room the machine is in. Turn the machine back on. On the right side of the machine, there is a slotted area where the fan it, look in there and watch for a glow in the machine. Give it a minute or two, but if you don't see that glow, those heaters are not working.
They are not impossible to change, but requires some patience and care in replacing.
They are only, well if you live in North America, 120 volt, 150 watt halogen lamps. The simply burn out a filament.
You can go to Lowes or Home Depot and buy those. Or some local service Dealer could do that for you at a decent price.
If you want to try replacing those yourself, let me know, I will send you the procedure. Provide me your E-mail address and I will tell you how to replace those.
Please, do not pay the Xerox price for a new drum heater assembly, you will be stunned what they want for that item.
It really only requires replacing the bulbs, and most likely cleaning the contacts with some emery cloth.
Apr 18, 2008 | Office Equipment & Supplies
Xerox Phaser 8200 Laser Printer Logo
71 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
