Question about Dryers
Running 10/3 wire and wiring clothes dryer directly. The dryer does not have a ground connect for the bare copper ground. Can it be connected to the white neutral at the dryer?
    Genius:
  • 1,028 Answers
NO!! use the green screw on back where cabinet ground goes red to red white to white black to black remove cabinet ground wire and connect it up to white neutral on dryer connect bare ground to cabinet ground screw ..but wouldn't it be better to connect wall plug to house wiring and correct cord to dryer? always hate working on hard wired equipment since a lot of breakers are never labeled or relabeled correctly
Posted on Jul 15, 2008
How to connect 4 wire pigtail to 3 wire dryer
connect directly to dryer. There should be a connecting block in back of dryer marked for blk.hot wire,white commen wire,and Green or bare ground wire & add another ground wire from a screw on dryer to green ground wire at the block.To be safe,check your owners manual. PS always be sure your pigtail is unpluged.first.
Sep 27, 2014 | Whirlpool GEW9250 Electric Dryer
Wiring a Westinghouse 3way speed switch.
Three way Switch installation; One cable has two wires plus a bare copper grounding wire, The other cable has three wires plus a ground.
1. Connect the black wire from the two-wire cable to the dark common screw terminal. 2. Connect the red and black wires from the three-wire cable to the traveler screw terminals. 3. Join the white neutral wires together with a wire connector and pigtail the grounding wires to the grounded metal box. 4. When the switch lies at the end of the circuit one cable enters the box. 5. The cable has a black wire, red wire, and white wire, plus a bare copper grounding wire. 6. Connect the black wire to the dark common screw terminal. 7. Connect the white and red wires to the two traveler screw terminals and the bare copper grounding wire to the grounded metal box.
I hope this help.
Mar 29, 2013 | Electrical Supplies
Wiring conia ccd4501
There could be two situations for you. For the wall outlet, you may have a four prong plug or a three prong plug. For a three prong plug the outlet has three prongs and the terminals inside match up with these prongs. The two slanted prongs on the top are the hot terminals and the red and black wires get connected to these (order doesn't matter but keep the wires matched up with the terminals on the same sides). The white wire is connected to the "L" shaped prong, the third lower prong. The bare copper wire is just bent out of the way. At the dryer for the three prong there will be three terminals 2 hot and one neutral. Usually, your dryer cord will have the neutral as the middle wire, but pay attention if your cord wires are color coded (where white will be your neutral wire). At the dryer there is a terminal which is connected to the frame of the dryer by a piece of metal. This is your neutral, connect your neutral wire from your cord up to this. The other two wires get connected to the other two terminals (order doesn't matter but keep the wires matched up with the terminals on the same sides). For the four prong its very similar but there is a small change, that bare copper wire is now used. The terminals on the wall outlet will line up with the prongs. The two vertical terminals on the left and right are your red and black wires. The "L" shaped prong is your white wire. Now the fourth prong, the one shaped like a semi circle is the terminal you connect that bare copper wire up to that is your ground. At the dryer for the cord (If its a four prong cord your wires should definitely be color coded). The terminal that had a connection to the dryer frame now will no longer have one. The terminal thats connected to the frame you connect the green wire to. The terminal that was connected to the "green wire terminal' is now the neutral terminal and your white wire gets connected to it. The other two terminals are where your connect your last two wires.
May 10, 2010 | Dryers
Can i switch the plug on my dryer
If you change the plug on your dryer to a three prong and plug it in that way it will work, however it will not be up to the latest electrical codes where the dryer needs to have its own ground, not share that ground with a neutral. I would recommend running a new wire 10/3 with ground with a new four prong outlet (note: if you already have the 10/3 wire there you can just as easily change the outlet; red and black are hot wires, white is your neutral, and the bare copper is your separated ground) . However if you would like to just change the plug to a three prong you have to make sure your ground bar is tied to your neutral bar and there you only have three wires, 2 hot and one neutral.
May 03, 2010 | GE DBXR463EBWW Electric Dryer
Im install a newer 220 dryer.why the different plug/outlet configuration how do i wire this
I'm assuming you mean why does it have 4 prongs instead of 3. Well the new code requires dryers to have a separate means of grounding (have its own ground wire) where as before there was not a separate ground wire, the frame of the dryer was simply jumpered to the neutral wire. The problem in doing that is if there was ever a ground fault it would not go through a separate wire to trip the breaker but the neutral wire which is already carrying current ending in a dangerous short circuit. That being said, your cable going into your outlet should have 4 wires, red black white and bare copper, your new outlet has to have the bare copper connected to the lower prong. And your dryer needs to have the jumper from the frame to neutral removed and you need to connect the green wire from your plug wire assembly to the frame of your dryer. Should your wire not have the correct number of wires your local home depot or lowes will sell a electrical wiring book that can show you exactly how to run the new wire.
Feb 25, 2010 | GE WBSR3140DW Top Load Washer
How to ground receptacles in home basement
you need a 2 wire with ground. Some older homes were wire with just a 2 wire. you can take a wire from the nuetral and connect it to the ground screw to trick testers into thinking it is grounded properly, but i would not.
Dec 06, 2009 | Irons
Evaporaive cooler wiring re-connect
I would think you want to connect the green wire to chassis. The idea being if any component shorts to the chassis the unit would grounded directly to earth.
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
Replace a 3 wire power cord with a 4 wire power cord.
red on one end, black on the other, white in the middle, green to cabinet ground.
Jun 12, 2009 | Dryers
Trying to wire a 3 wire dryer from panel box to dryer plug
Sounds like you have a 10-2 NM wire. One black, one white, one bare copper. At panel box, black to one hot terminal of breaker or fuse holder (L1). White to other breaker terminal or other fuse holder (L2). Bare copper to the grounded neutral buss bar.
At the dryer the bare neutral goes to the center terminal, the other two go one each on either side, it won't matter which way. Hot Neutral Hot. The neutral terminal of the dryer should have a wire or metal strap connecting it to the dryer frame if you are not using a four wire supply.
Oct 22, 2008 | Dryers
Open Questions:
Dryers Logo
Top Dryers Experts
