Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Please
quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE METAL
CASING. There
should be a 14 character Serial Number beginning with RG or RN or PH or similar
(often found stamped in the metal casing ) and maybe a Security Number in the format of
TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING
you can find
The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number beginning with RG or RN or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
The radio will have to be removed from the car dashboard . Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING. Also confirm the MAKE of CAR it is fitted into.
The radio will have to be removed from the car dashboard .Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
