Question about GE Nautilus 24" Built-in Dishwasher
Dishes come out with white stuff all over them
The dishes all come out with white streaks. not sure if soap is problem, but i have switchedsoap brands and got no results.
Dishwashing detergents have recently been re formulated and sulfates were removed. This has caused the dishes to no rinse properly in areas with hard water. The solution is too add a rinse agent containing citric acid. I got some today from our local appliance store and the dishes came out perfect!
Posted on Feb 27, 2011
Grit in clean glasses and on dishes
Mary do you have a water softener? If so, only use 1 tablespoon of dry dishwashing detergent per wash. Don't use tablets or liquid soaps. Too much soap will wear down the items you wash, leave streaks and pock your dishes. That might be what the sandy grit is. Also, to get rid of the grit inside of your washer you can buy a special dishwasher cleaner at almost any hardware store. Always try to use a rinse-aid. Make sure your drain filters are clean. Hope this helps. Jewels
Mar 15, 2013 | Dishwashers
Tip
White residue on dishes
This has become a huge problem and a big misunderstanding on what the white dried residue is on your dishes.....IS it hard water probably not . Due you use liquid or powder soap and fill both soap compartments !!!!ow<br /> <br /> well here is a solution first stop using to much soap!!! <br /> most people only need no more than a tablespoon of soap.... powder or liquid..total... dont forget that powder soap can go bad in those card board boxes in a humid enviorment,,,( under the sink) remove and discard any soap that's clumpy and pour rest in a tupperware dish...<br /> <br /> so here is how to remove white residue off dishes...<br /> <br /> Fill your kitchen sink with hot water no soap and 1 cup of vinegar let dishes soak dont let water cool scour dishes in sink no soap rinse them and air dry all dishes .... some dishes may be ruined due to how long white residue had been on them called etching..... now we need to clean the dishwasher start dishwashere like normal no soap and let run for few seconds when dishwasher starts to fill open door and pour in atleast 2 cups of vinegar close door and let dishwasher run cycle repeat necessary till residue is of wash arms racks door and cabinet walls ... these steps need to be repeated in most cases a few times ...
on Jan 27, 2011 | Dishwashers
Built-in dishwasher. dishes not clean, plus nasty white residue on everything...
Hi
The white residue is from the new environmentally safe soap. Check your soap and see if it is phosphate free soap and that will be your issue. Also either you have hard water or you're seeing either calcium or lime deposits. You should use the jet dry for every load. There should never be any suds in a dishwasher. Do not use liquid dish detergent for the dishwasher.Try running a load without dishes, using vinegar, or a bottle of Dishwasher Magic. Another possibility could be you're not getting enough water. The level should be close to the heater(check your tech sheet to be sure). The water temp should be at least 140 deg.F (no matter what the box says) Also, use a good brand of detergent (Cascade) and be sure your wetting Agent dispenser is full. (jet dry)You should not have to pre-wash your dishes..just scrape them well.The detergent actually needs some dirty dishes to work properly..fats, protien, etc. to make up 1 more chemical for the detergent.Another important step is to run the hot water faucet before running your d/w to "purge" the cold water out of the line.
Also check this links for some helpful information:-
http://www.appliance-repair-it.com/dishwasher-leaves-white-film-on-dishes.html
http://askville.amazon.com/dishwasher-washes-dishes-clean-white-residue-problem/AnswerViewer.do?requestId=6117170
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6192
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Aug 23, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
There is a white residue on my dishes when the cycle ends. I have switched soap brands and made sure the rinse aid container is filled. The residue is hard to remove, even with hand washing/scrubbing and...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Aug 29, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Leaving gray white streaks and spots on dishes
Check the following to address this issue--
1. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
2. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
3. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
4. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Jun 01, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
Soap build up on dishwasher. Dries white and stays on dishes.
the spray arms is eather bad or the wash motor ,,,,, it isn't spraying water onto the dishes with any force.
Larry
Nov 25, 2008 | Dishwashers
White Residue
most likely it is your detergent. palmolive eco is notorious for leaving a white chalky residue on dishes. try this out before calling a service tech: put unclean glasses in the dishwasher and in your soap dish and rinse cycle cup put 1/2 cup of distilled white vinegar. if it cleans (or improves) your dishes, then your detergent is the culprit.
Jul 29, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Maytag quiet series 300 dishwasher
try using less soap and make sure the dishwasher is filling with enough water.
Mar 02, 2008 | Dishwashers
GE Nautilus 24" Built-in Dishwasher Logo
98 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
