Question about Saeco Magic De Luxe Espresso Machine
From 1-7 on the coffee grinder, which is the finest grind.I Hve misplaced my manual
Saeco Magic De Luxe Espresso Machine I have my grinder setting on 2 and the amount on the ++++ side but still have coarse ground coffe that's more like tea. I have cleaned and lubed the machine well including the grinder (cleanded all the grooves out with a toothbrush) but continue to have the problem. Close inspection reveals no obvious problems.
  • 515 Answers
If you take of the bean hopper and the adjustment pin, then you can turn the outer ring clockwise 4 step.
Check also that the ring not is loose.
Posted on Jul 15, 2008
Two weeks ago I paid > $100 for a full service (Saeco Magic Deluxe) and now the machine won't grind the coffee beans. Any suggestions so I can be a bit "knowledgable" if I need to take it...
Hi
If the grinder is spinning your grind set is too fine. Push the lever below the bean hopper to the back. It can go to a coarser setting anytime but the grinder has to be spinning to make it finer. They may not have set the grinder correctly. Have them walk you through the process. It also takes about 2 to 3 times before the grinder fills to work.
Apr 13, 2011 | Saeco Magic De Luxe Espresso Machine
Tip
Fix Saeco Magic De Luxe Not Grinding problem
If you leave the machine for a while, the residual ground beans in the grinder stick and clog the grinder.
- thus "timing out" with the "No beans" light.
After taking apart the grinder and cleaning it out, it still didn't grind. -
Then we ran some ground beans through it a couple of times, and then put fresh whole beans on top of the preground, and it took.
Worked great after that.
on May 06, 2009 | Saeco Magic De Luxe Espresso Machine
I took apart my saeco magic de luxe grinder .....I forgot to mark the settings....on the inside there are a blue & red mark...when aligned with the blue lines I can remove the grinder unit....I do not...
Here are the directions on how to clean out your grinder. Click here You will see what you are looking for in the document.
Hope I am not too late to help you. Good luck.
Mar 21, 2011 | Saeco Magic De Luxe Espresso Machine
My magic deluxe is grinding very coarse on number "1" grinder setting and the coffee is very weak; do you think the grinder blades are blunt? the machine is 13 years old.
Hi
Your grinder has seperated. The cork screw in the center is not centered. Grinder needs to be replaced. If you want one let me know.
Jan 21, 2010 | Saeco Magic De Luxe Espresso Machine
Poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
My machine is grinding the coffee ok, but it is not tamping the grind into tight rounds. Consequently the coffee is weak and the discarded coffee which is deposited into the dregs draw is loose. I have had...
First, have you tried adjusting the grinder to the finest setting, if yes and you still have the same problem the grinder needs adjustment, either the burrs are dull or the grinder needs to be set.
Saeco Magic de luxe not grinding beans
Try setting the grind to the coarsest setting, if you still have the same problem, check the wire connections to the board, it might have been reversed.
May 05, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
Aug 17, 2008 | Saeco Magic De Luxe Espresso Machine
1 would be the finest. I wouldn't recommend going under 2 though.
You risk clogging your grinder and machine under 2. There's also a dosage control when you open the door on the side. + means a bigger dosage or puck.
Hope this helps.
Oct 26, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe cleaning grinder
I don't know what you mean by disarming the grinder. Unless you are talking about using the bypass. If that is the case there is a button on the panel that has waht looks like a scoop. Push that button and put a scoop in the bypass door and then push the button for what cup size you whant. Regarding the taste of the coffee. It may need a cleaning and service. Try googling "saeco repair" and find an authroized Saeco repair center and have a good service done on it.
Aug 20, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
139 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
