Cassette plays too fast - Audio Players & Recorders
  • 2,071 Answers
The problem of your cassette is the motor, controler assembly switches the jonts of parts there is brittle or crack...Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If this solution help you understand the problem :rate as fixya..
Posted on Jul 15, 2008
Denon tape deck ddr m30 will not play cassette, but fast forwards and rewinds fine, it just wont play!
There may be a separate motor for the play function and either it or a drive belt has failed.
Jun 17, 2016 | Denon Audio Players & Recorders
Panasonic SC-AK45 stereo not playing cassette tapes
I may not have worked on one of these before but all tape decks have some common drive parts. Yours is missing the proper torque to drive the reel table in take-up for play and your fast wind observation also points to either drive transfer problems or the motor itself. I suspect the fastest answer is to have a tape deck technician work on it. Dual cassette decks are not known for being the long lasting products like a singles cassette deck is.
Feb 23, 2013 | Audio Players & Recorders
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
All cassette play too fast
I think that the rubber wheel pushing on the tape and controlling the speed is stuck somewhere and this preventing him to stay on the tape and control its speed
Daniel
https://www.rylwy.com/carbon-antenna
Dec 24, 2017 | GPX HMTU3234 Shelf System
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
RCA cassette recorder/player keeps shutting off. argggg
fast forward, reverse the cassette and fast forward again. if the tape is too tight the current sensor will always trip out the motor.
Dec 03, 2007 | Audio Players & Recorders
Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
This is a fairly old and obsolete model and its components are now not manufactured. If you are lucky, some stockists may have replacement part, but normally at very high price.
Nov 06, 2007 | Audio Players & Recorders
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
 Grubhead
Grubhead
