Question about Amana Dryers
I have an Amana Elec. Dryer. Model # DLE 330 RAW that all of sudden quit heating. This dryer is about five years old. It has 7 cycles and 3 temp controls. Could this be a bad heat control switch or a heating element problem?
    Novelist:
  • 177 Answers
It could be a circuit breaker, fuse, or electrical problem. Just because the motor runs doesnt mean it will heat.
You should check for power first.
Then unplug the dryer remove the lower front panel, two screws.
Mark and label any wire you remove so you know where they go!
in the back on the left is the heating element, check for burnt wires, take the element out and check for a broken wire on the back side also check all the thermostats, and electrical components to make sure they are good.
ask more questions if needed
Posted on Jul 17, 2008
Have a five year old Amana Gas Dryer Model Number NDG5805 that makes a buzzing sound only when it is heating, what could be the problem?
the gas valve coils on the gas valve body that hold the gas valve open to supply gas to fire the burner are getting loose and need replacing
Mar 08, 2011 | Amana NDG5805AW Gas Dryer
Where is the heating element on a amana dle dryer
Depends on the model. Usually on the back lower left side under tub or right behind the tub in the top center. The frist location you remove the front panel to get to element and the second location the lid has to be raised up
Mar 02, 2010 | Amana DLE330RAW Electric Dryer
No heat
Your problem is more than likely one of the following:
* heat source: elec. heat element, gas coils, gas igniter or radiant sensor (depending on elec. or gas model)
* thermostat
* timer
Feb 19, 2010 | Amana ALE866SB Electric Dryer
Severe noise - drum is jammed and won't turn - LG DLE-5977 dryer
A piece of clothing is probably caught in the blower wheel.
Remove lint filter.
Use flashlight to look into filter housing to the lower left.
You may be able to retrive the item if you can see it.
Try rotating the drum in both directions while looking.
Jan 07, 2010 | LG DLE5977 Stainless Steel Electric Dryer
5 Year old Kenmore Elite Electric Dryer will not heat.
limit switch either the one on the heating element or the one in the air duct they are easy to check if u know how to use a meter they should read continuity when they are cold and open up at a certain temp
Aug 24, 2009 | Kenmore Dryers
Amana dryer dle330raw tenson on belt
Usually very simple. You need to get the diagram for our model. Most dryer belts go around the drum, around the tensioner pulley and around the motor pulley. You need to take off the front, top and rear panel depending on model. I can change mine in about 15 minutes complete job.
Jan 08, 2009 | Kenmore 82822 Electric Dryer
Maytag PYE3300AYW Elec Dryer Runs, But No Heat
hello kellygubser,
If you are sure the thermal switch is ok.. have you checked the high temp ( bi metal snap switch) too? Here is a link to the wiring diagram of your dryer. You can see that there are a few other temp switches in circuit of the heating element that would disble it.. Hope this helps
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
I have an Amana LEA30AW that is approximately 7 years old. It takes 2-3 cycles to dry. I have checked the voltage at the plug 240VAC L1-L2 and 120VAC L1 or L2 to Gnd. I cleaned the lint from the vent duct...
Ok your dryer is heating However it sounds like it is short cycling. Between the cylinder and Front and Rear bulkhead are seals. Take a bottom panel off the dryer and flash a light up at the seal area, while you are doing this look in the cylinder and see if you see lite, if you do this is were the air is leaking thru causing your dryer to short cycle.
Replace both the front and rear seals, is a real pain, take your time and you will do fine.
Sep 29, 2008 | Dryers
Amana gas dryer only heats first 20 minutes
Check your ducts that the heat blows out through. make sure there is no plug up in the dryer or in the ductwork.
You may have a problem with the termosensor or the high temp cut out safety switch/sensor. This sensor would be somewhere in the exhaust of the dryer.
Feb 04, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
149 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
