Question about JVC XV-M567 DVD Player
Player doesn't recognize DVDs
When connected to the TV, the screen says "Now reading" and then stops (the same when no DVD is in the tray). I took it apart (because I like that sort of thing), and I found this information:
The DVD never spins. The trays (3 of them) will load the player, and the read head will move back an forth for placement, but the motor that drives the DVD (to spin it) never turns. I know very little about these types of motors, so I'm not sure what to do next. I'd really like to hear suggestions on this.
By the way, I spun the DVD by hand for awhile. I know I couldn't get the right speed, but I noticed that the "READING" message on the TV stayed as long as I spun the disk, so I'm convinced that the *only* problem is that motor or the power to it. I checked for cable problems and saw none.
  • Anonymous Jul 16, 2008
    Dan, thanks for the suggestion.
    I disagree with your logic since the player seems to try to recognize the disk when I'm spinning it manually, but I tried your suggestion ... tested a music CD, and it didn't spin and wasn't recognized.
    I took the player apart ... down to the motor. I found the motor to be a RF-300S-12350 and found reference to this motor failing in other JVC products. I also learned from looking at it that it's a typical electric motor and *not* a stepping motor (which I thought it was). Using an OHM meter, I found no continuity ... bad for an electric motor. By this time, I'd already broken parts beyond repair, so I continued my research.
    After taking the motor apart (more damage that can't be repaired, I found that the brushes on the motor had warn away (which is likely the cause of the failure. If I had a new motor, I could probably fix this, but it's not worth the time or effort.
    If anyone wants what's left (only the motor is broken at this point), post a comment here and we'll work something out.
I have this same problem as Ketterling, but not as critical. After seeing the "No Disc" error I took unit apart. I could see the unit try to spin (sometimes), but would stop and get the error. I was fortunate that I could actually get it to work with a little help to the spindle assy (calibrated index finger-right hand). I could get it to work for a whole dvd, but it wasn't consistent. The problem returned and needed my assistance. I too have read this is a common problem for this model of DVD player (JVC XV M5658K and similiar models). I am looking for one of these motors (RF-300S-12350), but haven't found a solid supplier yet. Anyone actually buy and get one delivered to them?
Posted on Aug 31, 2008
  • 4,234 Answers
I hate to be the bearer of potentially bad news, but the problem is not likely the motor. The player attempts to detect a disc present, once that has been completed, the disc will be spun. Since you have the unit open, try cleaning the lens using a cotton swab and alcohol. Next try a music CD. If the CD will play but the DVD will not, the optics have failed and need to be replaced.
Keep us posted.
Posted on Jul 15, 2008
  • ABRsvcs Jul 16, 2008
    Well, I have repaired 100s of DVDs and CDs. Failing motors are rare. Yes this motor is a common one that should be readily available. Please note that the CD table height (the part that the DVD/CD sits on) is critical. There should be a small plastic height guide attached to the mechanism. It will look like the letter U. Detach this and place it between the CD table and the frame. That should give you the correct height. These motors are available using hte RF-300 number and run about $6 or so.
I have been playing DVDs without problem for several years on my RCA 20F510TD 20 in. TV/DVD Combo. Now when in the DVD mode, with a disk inserted, the screen comes up with no disk found. What can I do
NOT much you can do---It is a bad optical unit inside the DVD unit---they do not see parts----only the complete DVD portion----much cheaper to go out and buy a DVD player and connect it to the audio and video jacks this unit should have.
Mar 22, 2012 | RCA 20F510TD 20 in. TV/DVD Combo
Have panasonic dmr-ez485v error message -NO READ- changed disks used prerecorded movie same as my recorded disks, hit reset - still no change
I just saw the date on this message and realize that it was awhile ago. I assume that you have dealt with it by now... So for others who are trying to fix their DVD player:
I have a DMR-EZ485V DVD player and just started getting the error message "No Read." I couldn't find an answer on the internet and finally called Panasonic's customer service, (there is no charge 1.800.211.7262). Since it says "No Read" to everything--store-bought DVDs, burned DVDs, CDs; AND when there is nothing in there (it acts like it is trying to read when the tray is empty), the customer service rep thinks that I am having a lens issue. It either needs to be cleaned (can pick-up a product at Best Buy or Radio Shack) or, if that doesn't work, the lens needs to be replaced.
Aug 09, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Dvd player not reading dvds
si reviso bin las conecciones prueve el dvd en otro tv
Aug 24, 2009 | Cyberhome CH-DVD 300 DVD Player
TV/DVD player will not recognize DVD disks
Please check these things:
1. Are you placing the disk with correct side on the tray.
2. Is your DVd player has a region lock for the DVDs you are playing.
If above question are not true then you must go to the reapir man.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Dec 22, 2008 | Toshiba Televison & Video
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Should it burn
  1. DVD-RW reads and burn DVDs and CDs with or without a tv connections (computer accessory)
  2. DVD-R if its is a dvd player it should be able to read DVD and record dvds with tv connection (this is not a computer accessory but a tv accessory)
  3. DVD-ROM can only read and can not write on DVDs
Jan 11, 2008 | Computers & Internet
DVD appears to not be reading or recognizing discs
Unfortunately your DVD drive mechanism looks to have bit the big one.
You can try taking it apart, removing the top of the drive and cleaning the lense. Work it up and down. Use a q-tip with a little squirt of windex on it.
Reassemble and try it again. If you get the same results, it's time for a new DVD player.
Dec 27, 2007 | Toshiba SD-V392 DVD Player/VCR
Denon 3910 won't load some dvds/cds and vibrates while trying.."disc error"!
I have the Denon 2900 (about 4 years of use) and until recently, suffered from the same (growing) problem. CD's were very difficult to start/read. I recently found advice which I tried and was succesful with. It was manually cleaning the laserlens. I took away the outer housing by unscrewing all off the on top (6), side (4) and the back (2) bolts. After that I took out the top plate of the laserunit which took two very little screws taking out. Now you are looking at the cd-tray with the lens. Take a very soft and clean cloth and moisten it a little bit with clean water (be very carefull with the moistening, don't allow any waterdrop to come out of the cloth into the laserlens while cleaning! Carefully clean the lens and dry it with a dry part of the same cloth. Replace the top plate and the outer housing and the player will recognize the discs like it's new again. Good luck! Robert Jan, The Hague the Netherlands
Dec 25, 2007 | Denon DVD-3910 DVD Player
Phillips Home Theatre System
Once you have connected your dvd player to your tv and the tv is turned on. Turn on the machine and press "disc" on the remote control. Open/Eject the disc tray. Press STOP on the remote control. Enter the following numbers slowly on the remote control " 7,3,4,4,6,6,0". Configuration will appear on the bottom left hand side of the TV for three seconds. Press "PLAY" to close the tray. The DVD player eill return to normal operation. This SHOULD make the player Region free.
Sep 01, 2007 | Audio Players & Recorders
JVC XV-M567 DVD Player Logo
320 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
