Question about Ricoh Aficio 450 Copier
Richo Aficio 450e photocopy machine (Error Code SC360)
I need help . my machine is showing sc360 error how do i clear it and have my machine up and going
HELP
    Problem Solver:
  • 19 Answers
Replace HDD
Posted on Dec 24, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ricoh Master
  • 1,362 Answers
I can't find that code on my site, look and see if you find it
http://checkitright.spruz.net/?page=dp&dis=834222
Posted on Jul 15, 2008
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
SC360: Hard disk drive error 1
-Definition- [B]
The machine does not detect the connection signal from the HDD.
- Possible causes -
· Poor connection between the HDD and HDD controller board
· The ac power connector to the HDD is disconnected.
· HDD defective
· HDD controller board defective
· BICU defective
Posted on May 06, 2014
Aficio SP C820DN. How should I respond to error code SC360?
  • TheVt value of the blackTDsensor exceeds the specified value (default: 4.7V) with SP3020-002 for twenty counts.
  • The[Vt-Vtref]value of the black TD sensor exceeds the specified value (default: 5.0V) with SP3020-001.
  • Push the decal (three green lines) attached to the lever using your finger, for all four PCDUs.
    Check the pentagon-shaped window for all four colors. If you can see a red area, as shown in the "Incorrect" photo below, this means the unit was not installed correctly.
    Make sure that the white locking tab on the PDCU (circled in red below) is inside the hole of the bracket. Do this for all four PDCUs.
Feb 13, 2016 | Ricoh Office Equipment & Supplies
Can I remove screws from the Shark SC360 Steam Cleaners?
Yes it is possible thats why they are there to fix any possible problems just need a bit to match the screw head it maybe a torx bit t15
Mar 10, 2014 | Televison & Video
Mpc2500 sc360
black TD sensor error ,
may be the machine pulled alot of toner
you can copy black paper to fix it
i am waiting your feedback
Dec 26, 2011 | Ricoh Office Equipment & Supplies
Looking for codes sc360 and sc990 gestetner 5502
sc360 is a hard drive detection error. The hard drive might be either defective or disconnected, or one of the connectors might be loose. If you know the hard drive is good, check its power and data cables and connectors. In rare cases, this error can point to a faulty BICU board.
sc990 is a general software error. This error is often logged in conjunction with other errors, and may not necessarily represent a separate problem.
Your best bet is to check the hard drive first -- maybe try formatting it or replacing it if you have an extra one. Good luck!
Oct 19, 2010 | Gestetner - 5502 Digital Imaging System...
In Ricoh aficio 401
The SC360 is Hard disk drive error 1. This means that the machine does not detect the connection signal from the HDD.
CHECK THESE; poor connection between the HDD and the HDD controller,
the AC power connector to the HDD is disconnected,
HDD defective,
HDD controller board defective,
BICU defective.
Make sure all connections are tight and secure, make sure power is connected securely, make sure HDD ( hard drive) is not bad if so replace. If the above are fine, replace the controller board and if the problem is still there, replace the BICU board.
Nov 15, 2008 | Ricoh 6513 Copier
INFO
Get a new HDD for the SC 360
and connect the Exaust fan for the SC490 might be disconnected.
Both in the back of the machine.
Nov 10, 2008 | Ricoh Aficio 450 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Error code sc 490 and sc360
Did you try to rest the error? Do you know how too?
Feb 09, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
1,655 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
