Question about Ricoh Aficio 2015 Copier
Ricoh Aficio 2015
This machine ( Ricoh Aficio 2015 i)s giving me code error sc:552 and is not letting me do any thing press any botton and nothing happens please can you help
  • Ricoh Master
  • 2,794 Answers
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Posted on Jul 17, 2008
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Aug 18, 2008 | Ricoh Aficio CL7000 Laser Printer
RICOH AFICIO SP C811DN
press the up/down arrows together for @ 5 seconds, then hit "ok".
scroll to "engine"
look for 5-810 -SC reset, hit "OK" turn machine off/on using toggle switch.
May 09, 2014 | Ricoh Aficio SP C411DN Laser Printer
Error code sc 542?
1. Press Yellow Botton.
2. Dial 107
3. Pess and Hold Orange Botton until you hear noise.
4. Press COPY SP
5. Turn off and then Turn on the machine.
Good Luck
Jul 14, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Oct 18, 2008 | Ricoh Aficio 2015 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Error sc 490
try to rest the code by hitting the Yellow clear botton, then the numbers 1-0-7 then press and hold the red clear/stop botton for three seconds. The screen will change and then turn the copier off. this should reset the code.. That is if there was a power problem. Try it and see what Happens..
Feb 12, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 2015 Copier Logo
465 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
