Question about Frigidaire Affinity ATF7000E Front Load Washer
No panel lights!
Dead! Panel lights do not come on when turn knob. Stacked dryer works fine. Only washer won't start. Affinity frontloader.
Solution - MEASURE voltage in outlet with digital meter and if it is not ~115 V or very close do nothing - wait till it gets to norm.
Longer explanation:
I had similar problem today. Dryer fine, washer (front loader Affinity 6000) dead. Electric power there. Day before had no electricity for few hours. Turned out to be that this thing is sensitive to voltage. I have now from 101 to 103 volts and it needs something close to 115. I have almost disassembled it but it was hard to do and no manual on web (except to purchase for $15). So, after removing back paned and few screws from front I have turned my attention to my UPS I have for TV - it sometimes would blink with blue diode (means it is starting). I thought why... Then I have luminescent (energy saver) lamps around house and those are not sensitive to voltage so lights are fine. In bathroom however I have halogens and those seemed dim. This time I have looked at my tester again and noticed that it shows ~101.2 volts. So I am taking UPS from my TV and moving it to laundry, plug UPS to outlet, washer to UPS - washer still dead. I unplug UPS from outlet and washer comes alive...
Hope this helps.
Orest Dmytryshyn
Edmonton, Canada
Posted on Feb 02, 2009
My affinity front load washing machine will not start, there are no lights - nothing. The stackable dryer on top does start. Is there some kind of re start button for the washing machine
To Stranded,
Here is a link that will put you directly to free support and a manual to guide through the trouble shooting function. sparke needs help with Frigidaire Washer on ManualsOnline com . If you are familiar with a meter to troubleshoot and identify voltages. Start there. If the display is functional. Here is another forum you can tap for resources to compare. Basics first. How to enter diagnostic mode on Frigidaire ATF7000 washer Appliance... .
And you will need to take it apart.. here is the link for that solution.
Frigidaire Affinity Washer Disassembly
Say how you made out and if this approach helped please?
Fare. Well.
Sep 19, 2014 | Frigidaire Affinity ATF7000E Front Load...
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Dryer won't start in Frigidaire FGX831CS0 stackable. Assumed it was a bad start switch because honey bunny had broken the knob off and was using a pliers to start it but have replaced that and still nada,...
Check the door switch. Turn on dryer as you push in on switch where the door catch is and see if it starts . when closed the pin may not be pushing it in.
Mike
Jun 05, 2017 | Frigidaire FGX831CS Top Load Stacked...
On the Kenmore 70 series, can the buzzer be disconnected? Our 5 month old gets startled each time that damn dryer buzzes (It seems like it last forever!)
Hi, did you try turning the buzzer off with the knob on the right side of the operation panel (which is also used as the start button)? If you turn that knob to the left, it should turn off the buzzer.
If it still buzzes, the switch behind that knob may be faulty. You can get at it by removing the panel at the rear of the dryer (6 screws) and then you can test it and adjust its internal contacts if need be.
Hope that helps!
Mar 03, 2010 | Kenmore 98702 Stacked Washer/Dryer
Can't get the push-pull washer control knob off
push the knob in then turn counter clockwise it does not push on it screws on
Jul 10, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Kenmore stacked washer/dryer. Dryer runs fine but washer doesnt
push the knob in then turn it counter clockwise chek the lid switch it may be bad
Jul 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Frigidaire Affinity ATF7000E Front Load Washer Logo
188 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
