Cars & Trucks Logo
Posted on Jan 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Check engine all the time we replace crankshast sensor and still ligth come on check engine
Auto Repair Help
Level 3:
  • Saturn Master 1,420 Answers
  • Posted on Jan 18, 2011
Auto Repair Help
Saturn Master
Level 3:
Answers
1420
Questions
0
Helped
666894
Points
4361
Hello and Welcome to FixYa.com
Please tell me the code that is coming back in. I need this to help you better.
Thank you for using FixYa.com
Regards, Lee Davidian
Your FixYa Expert
Check ligth braek and battery ligth
If you can,go to Autozone,they will test your battery and alternator for free,only takes a few minutes,on your brake light,check brake fluid in master cylinder could be low, setting the sensor off.If your brake fluid runs dry,you will have to bleed,you may have a brake leak and check your brake pad and shoes,may need replacing.
95 neon broken off crankshast sensor in block. Can I push it through and remove pan to remove?
no. in order to take out the crankshaft, you need to remove engine.
I have a 1986 silver spirit which looses power .it will tick over and run for about one minute .when you accelerate it looses all power .is this a fuel starvation problem.if i turn the car off then start...
check fuel pressure, ignition source , timing,plugs ,dist& rotor ,coil ,sensors , does check engine ligth on or comes on . just turn key on no start see if check engine ligth comes on
1helpful
2answers
P1166 code displayed on 04 KIA RIO with 1.6 eng. The check engine light came on within 2 Hrs. running time after timing belt repl.
P1166 refer to O2 sensor heater circuits malfunction, HO2 Heater system electrical, bank 1.
I sent my honda accord 1993 to honda dealerepairer to get check why check engine ligths come on.they said faulty collant sensor/is this serious problem?and why if the check engine ligths comes onmy car is...
Your computer relies upon the temp sender to tell it when it should switch from cold to hot mode. If it gets faulty information to begin with, nothing else in the fuel/timing management system will work properly which can cause hard starting, poor fuel mileage and overall poor running.
The results long term of not fixing the problem can range from just having an engine that never runs correctly to one with severe and expensive failures. Replace the sender!!! They are relatively inexpensive and not terribly difficult to replace.
O.k i try to fix my jeep i check the engine ligth i ready change all the sensors what the engine ligth say aand still the same went i running just turn off
You knowed what code are there? Read the Check Engine Codes
If you change the sensors, Reset the ECU, sometimes they keep stored in the mmeory.
Hope this help; good luck (remember rated this help).
1helpful
The engine ligth is on the scnner say the code po
there are four O2 sensors,you need to check the sensor on the drivers side exhaust,the front O2 before the converter
1helpful
02 kia fail smog high nox
if the engine computer says that you have a slow O2 sensor what it means is that the sensor does not react as quickly as it should and it needs to be replaced. nox is oxides of nitrogen, a product of too lean combustion which causes cylinder temps to go too high. it sounds like replacing O2 sensor will make it happy. engine computer is having a hard time controlling lean/ rich fuel mix because sensor is slow to register changes, needs to have response time in milliseconds or engine computer can't operate properly. O2 sensors do wear out, normal service item. hope that helps
4helpful
Code P0330
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
Check the resistance of the knock sensor (compare it to factory specs)
The knock sensor is faulty and needs to be replaced.
Check for broken/frayed wires leading to the sensor.
There is a wiring short/fault in the knock sensor circuit
Check timing
1helpful
Check engine light on after overfill the tank. Check for codes at autozone, Change gas cap. Erase code. Ligth back on. Again to autozone. They say it is the gas cap. I let them know i have just replaced it...
You have a leak in the fuel system somewhere or a bad evaporative system sensor, the way the system works is the control module for the emission system pulls a vacuum on the gas tank and lines to check for leaks, if it can't get a certain vacuum level for a specified time it decides there is a leak and the check engine light comes on. This may be covered under the Federal Emissions warranty, call the dealer and inquire if the Evap System is covered.
Top Saturn Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Saturn Expert? Answer questions, earn points and help others
