Question about Fuji FinePix S5000 Digital Camera
Zoom error My s5000 barrell is stuck it just states zoom error on the screen and makes a noice like a motor is stuck, i have replaced the batteries etc, with no success, any ideas.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
We have a message coming up saying "zoom error"
If the camera was operating properly before the zoom error then the most common problem to a stuck lens is dirt getting stuck between the two lens barrels. There are a few fixes for this none are guaranteed to solve the problem and should not be attempted if the camera is under any type of warranty. They include removing the batteries for a few minutes, reinstalling the batteries with fresh once with full power, turn the camera on while holding the the zoom button. Another method is to see if you can provide extra power to the focus motor by having the LCD screen turned off. There my be a button that allows you to switch from the viewfinder to the LCD screen switch to the viewfinder and try several times to focus (just point the camera at different distant objects) and attempt to focus the camera. I hope this gives you the results you need because the other suggestions may further damage the camera and are only a (last resort) thing. One is with the camera turned on tap the body on a counter or table edge while trying to zoom the lens obviously in the opposite direction to where it's stuck. The last is to gently push the lens in with the palm of you hand while zooming in. All these are just suggestions and carry no guarantee of working and may further damage the camera. The biggest cause of this problem is dust from a camera bag or some other environmental condition like sand from a beach.
Jan 24, 2011 | Fuji FinePix S1000FD Digital Camera
Fuji s5000 zoom error
Stop trying to zoom in and out. The gear is going to damaged by dust. Visit your service center dont warry. Its just a dust problem. THey will clean the lens zooming gear and fix it for you.
Thanks & waiting for your feedback
Jan 31, 2010 | Fuji FinePix S5000 Digital Camera
Lens Error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 04, 2009 | Nikon Cameras
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Mar 28, 2009 | Fuji FinePix S1000FD Digital Camera
Zoom Error, Lens won't close
There are several causes for this to happen.
1. The lens assy is out of alignment and stuck; stalling the motor.
2. The motor itself is defect
3. If you can hear the motor working , then it will be a stripped plastic gear between motor drive and lens assy.
DIY repair not recommended (possible)
Mar 07, 2009 | Fujitsu Cameras
S5000 fujifilm
Was probably caused by the zoom carriage locking on power out due to batteries running low. Turn off camera, tap barrel with solid but non-metallic object and turn on. Did this two times and it worked for me on second.
Oct 16, 2008 | Fuji FinePix S5000 Digital Camera
Re- fuji finepix s5000 digital camera
when the camera is turned on the screen says zoom error and whem pressing the zoom button the camera makes a noise and the lens does not move
Oct 12, 2008 | Fuji FinePix S5000 Digital Camera
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
61 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
