Question about Kenmore Washing Machines
Kenmore washing Machine 4450290
The washing machine, (serial cc4901093) is going through the wash cylces but doesn't engage in the rinse or spin cycles. You can turn the knob too the setting but it just humms and nothing happens. Same thing happens durring the wash cycle, it goes to where it is suppose to start spinning and or rinsing and just stops and produces a small buzzing/humming noise at the cycle selection knob.
  • 1,028 Answers
Lid switch
Posted on Jul 15, 2008
Washing machine gets stuck each time on Rinse, Drain or Spin cylce and can't open door!
the drain pump cant get the water out of the machine check it and also check the filter maybe something stuck in it
Feb 10, 2014 | Tricity Bendix AW1000W Front Load Washer
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Wont spin drum for wash cylce or rinse spin cycle
first off how old is this machine?
you could look to see if the door switch is being made up, most problems come from the switch not being made up, it tells the rest of the machine to perform the rest of the functions, try that and let me know.
Mar 03, 2011 | Kenmore 44042 Front Load Washer
My kenmore washer spin cycle will not engage / motor is spinning but not engaging prop to spin out
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Sep 13, 2010 | Kenmore Washing Machines
I hear gravel noise when the machine changes cylces
The machine does a quick test to determine if the spline is engaged before spin commences. The way it works is the tub fills with water and floats for wash. When the pump removes the water for spin the spline don't always line up. So artificial intel will give it a slight test to see if the basket is locked. I have a bravos manual that shows how it works I know yours is an Oasis but I believe these are all basically the same. See page 23
Apr 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine Series 80 Kenmore wont drain water after it's RINSE cylce including the motor. It's like the TIMER stopped after the RINSE CYCLE. I think it's the timer.
does it drain after the wash cycle? if it does, then I don't think it's the timer. It uses the same contact there as for the rinse cycle. Do you hear the motor running as if it's trying to drain? If the motor is running, perhaps the pump itself is no good? Just a couple things to check. Hope it helps.
Sep 05, 2009 | Kenmore Washing Machines
Kenmore Elite Top Load..Rinse water keeps running in Spin Cycle. Clothes are soaking wet when spin cylce is complete
the fill valve is an electric magnet valve and sounds like it is stuck unplug machine disconnect water lines plug in and when u turn on does it click, if yes then unplug try to slide a long qtip in and if it goes in replace valve
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Open Questions:
Washing Machines Logo
516 people viewed this question
Sal De
 Brian Main
Brian Main
