Question about HP Computers & Internet
Floppy drive The floppy drive will not open when i push the button. It makes a noise like it is trying to open.
  • jordan king
    jordan king May 11, 2010
    is there a disk in it
  • 66 Answers
Pull it apart
Posted on Sep 04, 2008
Add floppy drive
What model Lenovo ??...
Because PC makers no longer include floppy drives in computers, many new PC users have never used one.
Nevertheless, there are many occasions when a floppy drive can be the most convenient form of file storage and transfer for small files.
On most Lenovo ThinkCentre PCs, a floppy drive is an add-on option and most packages do not include the device unless you specifically request it.
If you purchased a ThinkCentre PC without a floppy drive, you can add one to the system yourself and save some money vs. taking the system to a shop.
Shut down the ThinkCentre computer.
Disconnect the AC power cord and other peripherals.
Move the computer to a sturdy work surface.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Use your fingers to push inward on the two buttons on either side of the computer.
Lift upward on the front edge of the cover to open it.
Open the cover until it stands at a 90-degree angle to the computer chassis.
Disconnect the ribbon cable from the optical drive.
Lift up on the rear edge of the drive bay tray until you can see the rear of the CD/DVD drive.
Orient the new floppy drive so that the diskette slot faces down.
Connect the floppy drive cable to the motherboard.
Slide the floppy drive part way into the floppy drive slot.
While holding the floppy drive, connect the other end of the cable to the diskette drive.
Lock the ZIF connector on the cable, then slide the drive all the way into the slot.
Slide the blue drive lock downward to secure the floppy drive in the slot tray.
Close the cover and reconnect all cables.
Power on the computer.
The ThinkCentre BIOS detects the new floppy drive automatically and configures it as the "A:\" drive on your computer.
http://www-307.ibm.com/pc/support/site.wss/MIGR-51497.html
Lenovo support
Sep 13, 2013 | Lenovo Computers & Internet
Loud, grinding noise from garage door opener
Remove the cover from the motor housing and check the drive gear.
Jul 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a mad dog MD-16XDVD9A4 drive. Stuff got
You need to get a straightened paper clip, or similar stiff wire, locate the small hole in front draw of DVD, insert wire and push gently in, until you feel/hear a click, keep pushing and the draw will pop open.
Mar 08, 2010 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
My xbox 360 disk tray will not open it wont even open a little some one help me
have you tried to open the drive using the xbox dashboard, when you press the eject button does the power light flash? is there any noises coming from the drive when you try to eject.
It could be a faulty drive and the only way to get into the drive is by opening the console up and this could void your warranty. if your hearing noises (motor spinning) from the drive it could be the drive belt has snapped (like a small elastic band) you could have dirt in the gears and cogs jamming the drive. so you wouldnt hear noises (except the disc spinning if there is a disc in it).
if the power light flashes when you press eject more than likely it is the drive belt or dirt in gears.
Oct 31, 2009 | Microsoft Xbox 360 Console
Where do you insert a disk in a laptop
Check in right side of laptop .
You find i small button press it so you cna ejct it.
Also you can find with my computer .
open my computer thne right clcik on your cd drive icon then click on EJECT so your disk drive is eject.
Put your disk there.
Let me know if you need more assistanse.
Thanks.
Aug 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
When I open My Computer, my A Drive has disappeared.Where is it ?
hello...hi..u need to out or restart the unit then go to the bios settings then make choose none floppy drive..the floppy drive as of now is not use..the popular using now to make back up files is USB flash drive..Thanks and Good Luck..^_^..God Bless you....
May 07, 2009 | Computers & Internet
Floppy drive doesn't work.......not listed on My Computer
some one change your bios configuration and there make floppy drive disable you need to enable that then you can see your my computer list
Jan 18, 2009 | Compaq Presario 5000 PC Desktop
Cd rom drive won't open
i had the same problem i solved mine by using a knife and using the tip of the blade to push up and pull out on the drive while it tries to open and drive opened with out a hitch.. it turned out to be a gear problem with the drive.
Jan 07, 2009 | E-Machines emachines (emachinees) CD-ROM...
My floppy drive makes a rathling sound when turn on
well fistly floppy are old technology and they naturally make a sound when accessing files. however the sound get noisy and irritating when you try to access floppy disks that have developed bad sectors (physical damaged, viral damage, dusty etc)
if your floppy drive makes noise even with brand new disks then it would have accummulated dusts on its magnetic reading head the solution is using cleaning floppies which are becoming less available in shops these days (but are still there). Or if you up to practicall thing open and clean up the read/write head manually. dont worry the thing is close to what the radio cassette head look-alike.
Mar 11, 2008 | Teac Floppy Drive 235HF Internal Floppy...
Laptop keeps beeping and not turning on
I think you may mean the Hard Disk light not floppy, although, if you have a floppy disc drive, check there's no floppy disc in it as it will stop the boot up. But if it's not the floppy, and the hard disc drive light stays on, possibly the hard drive is faulty, maybe damaged sectors. The other maybe is a possible memory fault, although the beep codes can only be identified if you know the motherboard make. Your rating are important.
Nov 22, 2006 | Gateway M350 Notebook
Computers & Internet Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
