Question about Toshiba Satellite P105-S6104 Notebook
Laptop screen issues
I have a blue vertical line that came out of no where and i have no idea how to fix it.
  • davids_lady Aug 05, 2008
    thank you.it isnt too bad i am just worried that it could spread out.can it?
  • 321fords Dec 27, 2008
    Hello -
    I have the same issue with my Fujitsu laptop and I understand that the thinking is a bad pixel sensor. The difference with me is that the thin blue vertical line is only seen at the desktop and some internet pages, but not seen when open Word Docs or Excel pages are there. It is also not seen at the toolbar at the bottom of the screen.
    Would a bad pixel sensor at the edges of the laptop's screen not show the line on the toolbar or open Doc's and the like?
    Thanks for your time.
    Genius:
  • 2,028 Answers
This is a bad pixel sensor. Your screen has hundreds of vertical and horizontal pixel sensors on the edge, if one goes out on either end it causes a dead pixel line through the screen. Unfortunately, the only way to fix it is to replace the screen. If you can live with the annoyance, I've seen screens last for years with a pixel line without any other problems.
Posted on Jul 15, 2008
  • Ryan Rogers
    Ryan Rogers Aug 05, 2008
    This could spread, and then again, it may stay just like it is. There's no way of knowing. It's one of those "time will tell" situations.
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
Vertical line
Run diagnostics on the system, will determine if that is a hardware issue or something related to drivers.
For drivers - obvious first choice is to download the latest drivers from support.dell.com and upgrade
For hardware - you will need the LCD to be replaced, for the lack of other smaller parts you can't order from Dell.
Before you determine hardware, go thru the system teardown documentation and reseat all the LCD parts / cables (usually fixes the line issue, without replacement)
Sep 13, 2013 | Dell Vostro 1510 Laptop
Thin vertical blue ink bleed line from bottom of Malaprop screen - Fades over time
Yes, it's a screen problem. It could be a loose connection of the LCD and the motherboard or the lid lights gone bad. You can fix that by either resetting the connection of the screen and the motherboard or replacing the whole screen. You would need a technician to do that.
David
May 27, 2013 | HP Pavilion Computers & Internet
Why can i only see the top 1/5 of my screen on my dell inspiron laptop? the bottom 4/5 is white with many light green/blue vertical lines. computer seems to be working fine - i can see my screen saver...
A few things you could do to test out this issue.. is if you gave a desktop, try hooking up the screen from the desktop to the port on the laptop and seeing if it looks the same..
If it does look the same, then the issue is with your video card..
If the desktop screen looks normal, then the issue is with your laptops screen and it will need to be replaced
Oct 30, 2009 | Compaq Presario M2000 Notebook
Vertical Lines in Monitor
This is usually a screen problem and cannot be fixed however to verify if this is from the screen or from the video card you can connect a normal monitor to the back output connector of your laptop and check the display on the external screen.
This will tell you if it is the video card on the board or the actual screen. In either case it would be a hardware issue.
Sep 20, 2008 | Acer TravelMate 2300 Notebook
Vertical lines in my laptop screen
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
Blue screen with rows of white lines (not BSOD) causing laptop crash
A blue screen generally indicates an operating system error or hard drive failure. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a new operating system. If the hard drive won't format, or you have any issues during or after the install, then the hard drive has failed and will need replaced. You will need an operating system or recovery disc in order to do this. If this is a preloaded machine that didn't come with any discs, then you will need to acquire the disc.
Aug 13, 2008 | Dell InspironTM 1501 Notebook
Blue line on TV screen
Hi
Your TV has a vertical fault. Based on your description, chances are that it is the vertical IC that went bad. It is relatively a simple repair job and any person with basic familiarity with electronic components and circuitry and soldering would be able to do the job. Should you venture to do a DIY please be reminded of the standard safe practices involve when working inside a TV unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | Fisher PC-19S90 TV
Blue vertical thin line on Acer Travelmate 2410
It might be the case that the pixels of that line have become dead.This is a monitor malfunctioning and you shud report to your vendor.
Feb 04, 2008 | Computers & Internet
Toshiba Satellite P105-S6104 Notebook Logo
277 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
