Question about Pie Hon03 F/Mm Car Stereo Wiring Harness Honda / Acura Adapter Harness for Use with Hon03 F/Mm 2003 and Up Factory Navigation Radios
Re wiring i have no wiring harness in my car just bare wires what colour wire is for what function
Hello, I just installed the EV4300N 4.3'' dvd, lcd player. Everything seem to work, but my front left speaker is not working. Please help!!!
Posted on Jul 31, 2009
Yellow is constant battery source, red is switched for when the car is actually running (otherwise your radio would always come on and kill the battery),black is ground, blue is to power a amp and/or illumination, the rest, probably green, green w/black stripe, white, white w/black stripe, purple, purple w/black stripe, and gray, gray/black stripe are for speakers. Stripe is the negative. I dont know the which one is which exactly off the top of my head but u could hook each one up individually and hear which speaker comes on. I can't guarantee that every car is like that but I have put in a dozen or so radios in my time. Hope that helps
Posted on Jul 20, 2008
I have a 1995 saturn sl1. And i took out my factory radio and Will be putting in a JVC KW-AV50 stereo. My question is, how the hell to i wire the jvc up?
Get an aftermarket harness and dash kit for your car. Harness plugs into existing factory harness. Color coded for radio.
Nov 11, 2017 | JVC Car Audio & Video
Plugging the wires fromwire harness
wires in a harness are colour coded and the connectors will be alike so find the same wire code and plug the connectors together . Remember that there may be wires in a harness with out matching wires to connect to as factory harnesses are made for extra add on items as the accessories list rises.
Apr 11, 2014 | 2005 Chevrolet Trailblazer Ext
What wire color code (function) on a clarion arx5170 stereo
red wire is live (battery) yellow wire live only when ignition is on, black wire is earth(car body) there should also be 4 pairs of wires green,white,grey and purple these are your speaker wires you'l notice with the pairs of same colour eg white one is solid colour one has a black stripe the solid colour goes to live + on your speaker the one with stripe goes to - on speaker, same goes for the rest of the pairs hope this helps
Mar 31, 2014 | Cars & Trucks
LG Dishwasher Wiring issue
Yes the green goes to your bare copper wire, it is the ground. Black to black and white to white.
Jul 17, 2012 | LG LDF6920ST Stainless Steel 24 in....
I have a 1995 GMC c1500 sierra the radio wire harness has been cut i am trying to figure out the wires and what they connect to on the back of a kenwood cd player i have connected the basics but i sti
the wire colours for your truck will be different then the aftermarket radio
you will have to locate them and match the wires function and hook them up that way
step 1 - factory wire colours
Nov 27, 2011 | 1995 GMC Sierra C1500
I have to change the stereo system Car harness has
Check this link, should help, just scroll down the page a bit.
http://www.the12volt.com/installbay/forum_posts.asp~TID~114874
Aug 13, 2010 | 2002 Mitsubishi Lancer
1996 mazda b2300 manual blowing # 24 fuse, the ignition,clutch,starter fuse every time i turn truck over. Giggle the wires under clutch peddle replace fuse and it starts right up..why fuse keep blowing?...
They may not need to be replaced but they need to be repaired. Somewhere under there in that wire harness you have a power wire that has a bare spot chafed in the insulation. You'll have to unwrap that bundle, the one you jiggle, and check each wire carefully for a bare spot. Start with any wire that is red,pink, orange; those are the normal power wire colors, but don't stop if you find one. There could be more than one. Just tape over the bare spots, you don't necessarily need to replace them. If the wire harness has beeen rubbing on a piece of the car try to reposition it so this doesn't happen again. Zip ties work good for this. Hope this helps.
Aug 11, 2009 | Mazda B-Series Truck Cars & Trucks
Car radio harness colour code
work it out with a meter ,,,,find perm 12v feed neg and pos ---yes could be any coloured wire depending on car maker,after finding perm 12v feed for memory look for pos from ign switch,now speaker wires are easy as both will be same colour for a speaker but one will have a band through it if not sure or colour blind like yours truelly then use pos and neg on speaker wire till you hear a thump from speaker then you know you have the right wires and location of speaker ,,ie.. front left back right ect ....Now you are a fully experianced radio fitter ??
Dec 20, 2008 | 1993 Nissan Maxima
Wire a delco 6 disc cd changer to my car model #16235120
find a wiring harness for the car first it will fit onto the plug that comes on the car itself. then connect the bare wires on that plug to bare wires coming from the plug on the back of stereo (color coded)
Sep 24, 2008 | Chevrolet Cavalier Cars & Trucks
Pie Hon03 F/Mm Car Stereo Wiring Harness Honda / Acura Adapter Harness for Use with Hon03 F/Mm 2003 and Up Factory Navigation Radios Logo
217 people viewed this question
Top Pie Car Audio & Video Experts
xxxxxx xxx
Are you a Pie Car Audio and Video Expert? Answer questions, earn points and help others
