Question about IBM ThinkPad T30 2366 Notebook
T30 Power up problem
My T30 2366-91U power switch needs a multiple press to turn on. I thought that it might be dirt underneath the switch but it works with just a single press to turn off the power so dirt is not the case here. Everytime I turn on the power, I need at least 7 to 10 consecutive presses. Once 'ON' it remains till I need to turn it off, without any trouble. I did not change the CMOS battery though.
  • 1 more comment
  • Anonymous Oct 16, 2008
    Same problem. Replaced the keyboard, no difference?
  • blue_fire578 Nov 18, 2008
    When I try to power on the notebook with the battery installed it does NOTHING. When I remove the battery it works fine. If I install the battery after power up it will run on the battery only. Something with the battery installed is stopping the unit from booting. Suggestions?
  • rossdrive05 Mar 27, 2009
    I have the same problem, sometimes one press will power the computer up, sometimes it will require several presses to power up.
    Genius:
  • 2,028 Answers
The c-mos won't cause this. The power button is integrated into the keyboard, and uses the same connector as the keyboard to get power to the system. In most cases, the board with the power button (which is part of the keyboard) is worn out. Occassionally the keyboard connector will work loose or get a little corrosion or dirt and not make a good contact, check and clean the connection. If the connection is good, then I'm afraid you will need to replace the keyboard in order to cure the problem.
Posted on Jul 15, 2008
The t30 light goes immediately from green to orange and won't power up. I just replaced the fan
Remove all power sources(battery and AC adapter) from the laptop. With the power source out, press and hold down the power button for 15 seconds. Then, power on the laptop using the AC adapter only. If this does not work, issue might have something to do with the motherboard.
Jun 09, 2010 | IBM ThinkPad T30 2366 Notebook
My IBM T30 Think pad lap-top is stuck in power save mode.The battery is still charging fine,but the whole screen is black with no image when i turn it on.However when i switch it on,all the leds light up...
Try to power drain the motherboard.
please follow this steps:
take out the battery
unplug the power adapter
press and hold power button for 30 secs
put everything back in
power on the computer
if issue is not resolved. There could be a possibility that this is LCD problem.
May 21, 2010 | IBM ThinkPad T30 2366 Notebook
Ibm t30 laptop has no video at start up
Try doing a hard reboot.
Unplug AC and remove battery.
Press and hold POWER for 30 seconds.
Plug in AC.
Turn on.
Upon bootup insert battery.
If this does not work I regret to say the graphics card is busted.
Apr 26, 2009 | IBM Thinkpad T30 Notebook
T30 motherboard problem
press f8 on boot up. select safe mode
Go start>run
type msconfig
hide all micosoft items in services and deselect the remoaining
Also deselect any "dghdfg" looking items from startup
Reboot
Install CCleaner & run
Dec 12, 2008 | IBM ThinkPad T30 2366 Notebook
Ibm think pad t30
you need to be techy on this one. you need to open the laptop. before you do that, be sure to remove all source of power (ac adapter and battery). press and hold the power button to drain all excess power. check the motherboard and reseat the CMOS jumper. it looks like a tiny pin. after reseating the jumper, reconnecting power and turn on the laptop.
i hope this helps.
Sep 16, 2008 | IBM ThinkPad T30 2366 Notebook
Removing password on T30
YES.... providing that the hard drive was not completely re-formated before the windows OS was installed.
Usually, manufacturers leave a section of the HD for this so in the event that something goes wrong, you would be abke to revert back to the manufacturer's setup.
Simply follow the following instructions... :
1) remove power from the T30.
2) hold or tap the 'G' key on the keyboard
3) apply power back on T30 while maintaining step 2)
4) turn on T30 via power button while maintaining step 2)
5) T30 should eventually boot up and in factory default settings.
If this doesn't work, repeat process or the T30 was configured to disable the 'G' key. In this case you need to reflash the firmware on the T30.
Aug 29, 2008 | Compaq EVO T30 Network Terminal
IBM T30 won't boot with LCD, but will boot OK with external eonitor
It means computer developed oxide on some contact, and this is causing a short that forces unit to shut down, laptop must be taken apart, dried properly, and eventually cleaned with circuit cleaning solution.
If problem stops when you turn to external display, then probably it is water or oxide in LCD ribbon cable connectors.
Aug 10, 2008 | IBM ThinkPad T30 2366 Notebook
T30 won't turn on
It might have some statical lockup
Here is the steps that you may try
Disconnect the AC adaptor, take the battery out, press the power button and hold about 7 second. Connect the AC adaptor and turn the unit on. If issue persists please post for further diagnostic.
Good Luck
Jan 27, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 no power
I agree with you and have a link for adapters http://www.google.com/products?q=IBM+ThinkPad+T30+2366+adapter&hl=en&rls=com.microsoft:en-us&um=1&sa=X&oi=froogle&ct=title
Aug 02, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
661 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
