Question about Whirlpool Refrigerators
Whirlpool model ed2vhgxmt00 quit cooling - Whirlpool Refrigerators
    Scholar:
  • 135 Answers
Helo sir
  • Check the temperature setting
  • Make certain there is a three inch space outside of the refrigerator between the walls and the back and sides and at least a one inch gap above, to allow for air flow
  • Clean the condensor coils
  • Unplug the refrigerator, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the temperature control
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
  • thank u
    Posted on Jul 15, 2008
    • Harrish Mugundhan Jul 15, 2008
      also this i found in whirlpool support
      • Make sure the refrigerator is plugged into a grounded 3 prong outlet.
      • Check the outlet. Does anything work using that outlet?
      • Check that the circuit breaker is not tripped.
      • Interior lights on some models will turn off if the door is left open for more than 10 minutes. Close and re-open the door to make sure the light comes back on.
      If the refrigerator compartment light does come on, but the refrigerator is not cooling, make sure the Cooling control is turned on.
      Given the refrigerator is equipped with a Cooling On/Off feature, there will be a Cooling On/Off button located on the control panel at the top of the refrigerator compartment or the feature can be turned on using the Lock and Fast Ice/Cool buttons on the dispenser panel on the freezer door.
      Cooling On/Off button on control panel in refrigerator compartment:
      Cooling On/Off feature on dispenser panel on freezer door:
      If Cooling is off, press and hold the "On/Off" button on the controls in the refrigerator compartment for 3 seconds or press and hold the Lock and Fast Ice/Cool buttons on the dispenser panel at the same time for 3 seconds.
      See also: Refrigerator or freezer not cool enough - Side by side refrigerator
      See also: Refrigerator or freezer not cool enough - Top-freezer refrigerator
      Once the refrigerator is turned on, allow 24 hours for the temperature of the refrigerator and contents to completely cool.
    Whirlpool oven rbd275 fan
    Yes, you can do this. Oven cooling fan working at 120V
    Nov 06, 2017 | Ovens
    Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
    The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
    Apr 15, 2010 | Whirlpool Dryers
    Whirlpool
    How to check stuff>
    http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
    . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
    Is the compressor motor running.If no check starter/overload relay.
    Oct 03, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
    Have a Whirlpool refrigerator that has stopped
    replace the electronics on the compressor --if you would like more tech diagnosis let me know
    Aug 10, 2009 | Refrigerators
    I have a Whirlpool refigerator model ED5THA that has quit cooling. The blower fan still operates and the lights come on but it does not cool. The problem just began yesterday. I think it is probably the...
    It's likely the start device on the compressor. If you hear clicking sound every few minutes - that's likely it. Turn off the fridge, remove the start device from the compressor and shake it - if small pieces looking like sand start falling out, replace the start device. Part number is on the device itself.
    Jul 04, 2009 | Whirlpool EL7ATRRKS Refrigerator
    Whirlpool Fridge and Freezer quit cooling properly at the same time.
    You likely have a defrost system problem.....call a service company to look at it.
    May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Whirlpool Model AD40USL5 Has quit pulling out water. I cleaned the coils but if sounds as if the compressor starts and then cuts right back off
    HI thanks for your question. so you did clean the coils ok. i think the problem your having is with the relay. check that. try and turn off, for a few hrs, the compressor is very hot . let it cool off. and try again. thanks the appliance doc. please rate my answer. thanks.
    Oct 09, 2008 | Whirlpool Refrigerators
    Whirlpool Refrigerator - Model# ED22LF
    Tom, I would start with the overload and relay that is on the compressor, If it is white it's a good possibility that it has failed. The fact that both sides are not cooling leaves me to believe the compressor is not operating. Take the overload and relay off. If they are both contained in a white cover shake it. If it rattles, I believe that is your problem. Let me know what you find...Catriver.
    Jun 28, 2008 | Whirlpool EL02CCXP 19" Cold Pals Compact...
    Whirlpool Frig
    Is that everything in your freezer or just in the fridge. Is this a frostfree model. Often if defrost fails in a frost free model then it is unable to duct cold air to the refrigerator side of things. To fix- turn it off for a day or two.
    Mar 16, 2008 | Refrigerators
    Whirlpool ev200nxr upright freezer not cooling.
    It is most likely the relay and overload or the thermostat.  What is the complete model # on the sticker inside the freezer?
    Oct 15, 2007 | Freezers
    Refrigerators Logo
    89 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
