We have installed the Roxio suite on a HP desktop running Windows XP. When DVDs are played they appear upside down, audio is okay and the timing is good. Do you know how I can resolve this problem?
  • Lenny12 Jul 15, 2008
    I like the way your mind works, it was a nice try and full marks for the logic. But unfortunately within the tools / Options there is not a switch or button to invert the display. I tried a few DVDs just in case I had picked up a dodgy one. I have also tried re-installing the application but there is no change. I have logged a call with Sonic, I will let you know when they come back to me. Thanks
    Lenny12
    Problem Solver:
  • 9 Answers
I believe that there is actually a setting in the settings menu that allows you to invert. Sounds like that somehow got checked. I don't have Roxio in front of me at the moment so I can't tell you for sure, but I would look for that setting.
Posted on Jul 15, 2008
DVD drive will recognize data discs but will not recognize DVDs. I.e. when you place a DVD in the drive and open windows explorer you are told that there is no DVD in the drive. However it will...
try running the fix-tool provided by Microsoft on this web page
http://support.microsoft.com/gp/cd_dvd_drive_problems
If that fails then my suspicion is that either
1) the drive has failed
or more likely
2) because you don't have any DVD burning software, windows can't understand the blank DVD-RW disk. This basic packet-burning software installed with XP CANNOT write to DVD disks.
However there is a bit more to it than that - the Microsoft CD burning software (which is a cut down Roxio product) cannot co-exist with any other packet burning software (e.g. DLA, In-CD or simuilar) so if one of those is installed you have to DISABLE the MS CD burning capability on the drive settings tab. Even worse, Internet Explorer 8 is not compatible with DLA - which is included in quite a few CD/DVD suites including many of the later Roxio versions
My advice would be
1) un-install any CD or DVD burning software on the machine
2) disable the MS CD burning
3) run that Microsoft patch
4) Install some DVD burning software but DON'T install the packet writing software part of it
Note that after installing that patch you may also have to reinstall any DVD playing software
Nov 21, 2010 | Acer Computers & Internet
DirectCD driver update
use system restore...or uninstall roxio and than reinstall....better u should go with system restore
Jun 15, 2010 | Roxio Easy Media Creator 10 Suite
Purchased roxio creator 2010 in store and roxio 6 & 5 on line
Uninstall the software, and try to get a refund.
Then, access http://www.MajorGeeks.com
and download the _free_ "Ashampoo Burning Version 6" software. It's great software for burning both data and audio CDs and DVDs, and it is _free_ to use.
Apr 07, 2010 | Roxio Easy Media Creator 10 Suite
Device reads cd but will not recognize a dvd
you may need the codec pack from
www.freecodecs.com
to play dvds. if you are running windows xp then it does not come with the codecs for playing dvds.
download the xp codec pack, run the installer and away you go.
Sep 26, 2009 | HP TS-H353B/HPBH Internal DVD Drive
This version of Windows does not support this version of Roxio DLA. This product, which was created by Roxio, Inc., has been blocked from running because it might keep your computer from starting correctly...
Getting older programs to run on Windows XP Getting older programs to run on Windows XP Most programs run properly on Windows XP. The exceptions are some older games and other programs that were written specifically for an earlier version of Windows. To run your program on Windows XP, try the following:
  1. Run the Program Compatibility Wizard. As an alternative, you can set the compatibility properties manually.
  2. Update your program, drivers, or hardware.
These options are covered in detail below.
The Program Compatibility Wizard This wizard prompts you to test your program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows 95, set the compatibility mode to Windows 95 and try running your program again. If successful, the program will start in that mode each time. The wizard also allows you to try different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
If compatibility problems prevent you from installing a program on Windows XP, run the Program Compatibility Wizard on the setup file for the program. The file might be called Setup.exe or something similar, and is probably located on the Installation disc for the program.
To run the Program Compatibility Wizard
  1. Start the Program Compatibility Wizard.
  2. Follow the instructions in the wizard.
Dec 19, 2008 | Computers & Internet
Problem: Roxio easy creator 10 installed on Vista ...I have downloaded all the software updates...Videoware will not run....need help!
have you tried changing the compatibility of roxio. All you do is left click the main folder in which all the Roxio 10 suite is install go to compatibility tab and check box next to run this program in compatibility mode make sure that in the box under this it says window xp sp2 then hit apply. If this doesn't work let me know if you are using the 64 or the 32 windows vista and i can help more.
Oct 26, 2008 | Computers & Internet
Flipped\upside down screen on my compaq
http://forums.techguy.org/tech-tips-tricks/336002-windows-xp-flipping-screen-upside.html
Windows XP: Flipping the screen upside down and back again
Once, at University, someone had flipped the screens of all the public computers (running on Windows XP) of the English Department upside down. The wallpaper, desktop icons, fonts, mouse-cursor and even the start-up screen...everything was displayed or moved upside down. People could not check out their e-mails or surf or do anything.
To reverse the upside down screen mode, press ctrl, alt and the up arrow (arrows console) at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again. If you possess a sense of humour or are antisocial, press ctrl, alt and the down arrow simultaneously, turn off the monitor, turn it on again and everyone (excluding the culprit) will be desperate --> upside down! Works for Windows XP Home and Prof.
Mar 31, 2008 | Computers & Internet
Roxio Creator Basic V9 that comes included with HP Pavillion Desktop does not install
The latest is Easy Media Creator 10 Suite.
This Roxio Creator Basic V9 came with your Vista machine?
But you have to install it yourself?
Or did you have The V9 already from another, older HP machine?
If so it won't work on Vista.
Nov 19, 2007 | Adobe Photoshop 7.0 for PC
Roxio 9
If you CAN, right click on the install utility icon and select 'Run in XP', then it should install.
If not then...
Roxio 9 is pre-Vista and out date for your computer, and can not run on Vista.
You should bite the bullet and install Roxio's newest version.
I believe you can still get it at a discount as a current Roxio owner.
Oct 24, 2007 | Roxio Cinematic for PC
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
