Question about Philips 37PF9631D 37 in. LCD HDTV
Sony KLV 40U100M turns itself on and off at random irregular intervals
Same problems as others on site.
  • Evelyn Roebuck Jul 15, 2008
    I have my tv at a local repair shop and they can't find the problem. What part needs to be replaced.
  • Evelyn Roebuck Sep 05, 2008
    Thank you sooooooo much.
    Evelyn
Had the same problem with my KLV-40U100M turning off and then on and it finally died. The repair shop stated the "A Board" needed to be replaced. So far it's still working. The repair cost $440.00, hope this helps.............
Posted on Sep 04, 2008
How to connect antenna to klv 40u100m
Correct. You have to connect the antenna to another box and then take the output of that box to the TV. An old VCR is ideal as this box.
Dec 20, 2013 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Power supplay 715t1756-f model klv-40u100m broken
It appears your looking for a power supply. Only place I could locate one was on ebay here http://cgi.ebay.com/1-789-496-11-New-Sony-Power-Supply-Board-KLV-40U100-/270664532068?pt=LH_DefaultDomain_0&hash=item3f04dd0064
You can also check shopjimmy.com but they were showing out of stock.
Dec 01, 2010 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
There is no picture and no sound on my sony bravia KLV-40u100m
Check the U24 (CPU reset IC) on the "A" board. It may be burned. If you have a DVM (voltmeter) check for 3.3V across SW1 connections near this device. If you don't have 3.3V, U24 is bad. This part is not available from Sony. The TV may work if you just remove U24 from the board. I posted this fix on Agoraquest also, you can read more there (I'm "Roundabout" on that forum). Hope that helps
Jan 01, 2010 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony KLV-40U100M Screen replacement
If this were just about any other brand, you'd likely be able to find another brand of TV with the same size screen and swap the inverter boards and the LVDS board. The problem with Sony is that the company uses internal designations. If you have homeowner's or renter's insurance, it might cover some of the cost. Otherwise, put the damaged set on eBay (you'll get a couple hundred dollars plus shipping) and go buy a new set. Likely, any larger set for sale with a good screen is going to go for more on eBay and finding one is rare.
Jan 31, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Tv don't turn on at all!
The U series has two boards and it could be either the system/video board or the power supply board. It will take a tech to tell you which is bad
Oct 17, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
Oct 08, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
HDMI and other outputs doent work
You may want to try a Manufacture reset. To do this you must first turn the TV off. Press in sequence.. Display-->5-->Vol +-->power on your remote(this sequence must be done fast). This should bring up a service menu. Press the number 8 and then Enter on you remote, The set should go off and on by itself. Now go through your setup and try the input again.
Best regards
Circuitcity
Dec 06, 2007 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony BRAVIA KLV-40U100M Issue
Just bought the KLV-40U400M Sony Bravia Monitor. Did you fix the turn on turn off problem? How much did it cost, labor/parts?
I'm thinking I better get the extended warranty although I wonder if the board will continue to go bad year after year.
I was told the tv could be replaced but w/someone else's refurbished tv. I was very unhappy w/that response.
So how's your tv today?
-Capri
Nov 03, 2007 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Philips 37PF9631D 37 in. LCD HDTV Logo
137 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
