Refrigerators Logo
A
Anonymous Posted on Jan 18, 2011
Have an LG SERIAL NO GR-B218JUDA THE PULL OUT FREEZER DRAW COMES OUT ONLY 1/4 OF THE WAY ON ONE SIDE IT APPEARS TO HAVE CEASED OR IS JUST STUCK ANY IDEA WHO CAN FIX IT
Anonymous
Level 2:
  • Expert 277 Answers
  • Posted on Jan 18, 2011
Anonymous
Expert
Level 2:
Answers
277
Questions
0
Helped
98105
Points
919
Is it ice build up inside the back? try dfrosting the fridge and see if that helps
2answers
I have an LG Refrigerator. GR-559FSDR 121T0063 Serial No. 102KRXD00130. It is giving an alarm like the door is open every few seconds. Both lights are off, when you open doors.
Check the freezer doors. Pull the tray out of the top drawer and see if there is ice build-up behind it causing it to not close all the way. I had to defrost my freezer to get rid of it. It also helped the ice fan from icing up stopping.
Water leaking in at the bottom of the freezer and the draw jamming with ice. This is a frost free refrigerator and freezer.
Sometimes a solid ground wire
wrap around the defrost heater and the other end stuck in drain hole has helped for me. Avoid letting the wire or whatever to touch the plastic side of the hole.
I have a LG GR-L207DUZA ''er ff''
i dont have the manual however.. this could be your freezer fan is perhaps seized.. you can test this by leaving your freezer door open to raise the temp and wait ti see if your fan comes on.. this may take upto 10 minutes so be patient
2answers
MY LG fridge model GR- M562 YLY
If you pull frig out from the wall, so that you can get behind it you will see a diagram with information on it. It states what happens with what test.
TEST1-All display lights come on
TEST2-Number 22 22 appears
TEST3-Number 33 33 appears
I have a question is your frig making a loud humming sound or a screach. If so it means that the fans need replacing.
2helpful
GE French Door 22 cu ft (PFSW2MIXSS). Loud buzzing from behind the freezer. Ceased cooling.
The model number you post appears to be incorrect.
The buzzing was from the evaporator fan blade hitting on some ice build up. Getting to it on a bottom freezer refrig is a bit of a pain in the back side. If your model has a pull out freezer drawer, that has to be removed, the icemaker removed, one side of the drawer supports from the freezer wall, all to allow you to remove the back wall of the freezer to get to the fan. You may be able to just thaw out the fan and surrounding area then which will get your refrig cooling again, if the ice was just around the fan area. On the pain in the but repair scale of 1 - 10, this one rates at least a 7.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
